center tunnel strength |
mrbubblehead |
Feb 17 2014, 11:56 AM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
I am wondering how strong the center tunnel is. after seam welding and the inner long kit, would it be ok to cut the top off for access panels? they will be replaced with aluminum panels fastened with rivnuts and 5mm screws. im leaving most of shifter sheet metal to keep the shifter solid. you can see from the pictures what i intend to cut out. (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1392659784.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1392659784.2.jpg) |
Cap'n Krusty |
Feb 17 2014, 04:32 PM
Without the pedal board, what do you use for pedal stops? Gotta have 'em, one to keep the throttle cable from too much strain, the other to keep the clutch cover plate from going over center ......................
The Cap'n |
Lo-Fi Version | Time is now: 1st June 2024 - 06:24 AM |
