| David Stowers |
Feb 22 2014, 05:06 AM
Member ![]() ![]() Group: Members Posts: 99 Joined: 28-June 12 From: UK Member No.: 14,613 Region Association: None |
On two occasions recently on pulling onto my driveway after a long journey my car won't restart after turning off to unlock the garage door. Luckily I can then just push the car in but with a European tour booked in the summer I'd like to sort the problem.
When I get back in after opening the garage the lights on the dash dim when I turn the key to start but there is no click. 20 minutes later it will start right up. Is this the problem that will be solved by a hot start relay kit or just a good old fashioned sticky solenoid? I'd rather do just the relay or just replace the solenoid so which is it? Thanks guys |
| toolguy |
Feb 23 2014, 11:17 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,277 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
Technically speaking, electrical current travels on the surface of a wire, not so much through a wire. . cleaning just the trans ground connection isn't good enough if the outside of the wire web of the ground strap is full of corrosion. . Same goes for the positive battery cable. . Often if you peel back some of the insulation at the battery terminal, you'll see the cable is coated with corrosion inside the sheath. . . . all this put together adds resistance and reduces the total current flow available to the starter. . If you have slow cranking then it may be time to replace the cables .
The relay addition is only for the circuit that energizes the solenoid and is good for prolonging the life of the ignition switch. . much easier to change a relay than find a good ignition switch. . |
| David Stowers |
Feb 23 2014, 03:28 PM
Technically speaking, electrical current travels on the surface of a wire, not so much through a wire. . cleaning just the trans ground connection isn't good enough if the outside of the wire web of the ground strap is full of corrosion. . Same goes for the positive battery cable. . Often if you peel back some of the insulation at the battery terminal, you'll see the cable is coated with corrosion inside the sheath. . . . all this put together adds resistance and reduces the total current flow available to the starter. . If you have slow cranking then it may be time to replace the cables . The relay addition is only for the circuit that energizes the solenoid and is good for prolonging the life of the ignition switch. . much easier to change a relay than find a good ignition switch. . Slow cranking isn't a problem, it's all or nothing. When hot the solenoid didn't move then 20 minutes later it span at a good speed and fired right up |
David Stowers Starter relay or no starter relay Feb 22 2014, 05:06 AM
Mblizzard Sometimes it is hard for me to get my head around ... Feb 22 2014, 05:48 AM
SLITS Put the relay in and forget it.
Current Bosch reb... Feb 22 2014, 08:22 AM
Luke M Here's a quick wiring guide.
You should be abl... Feb 22 2014, 08:27 AM
r_towle Might try cleaning your tranny ground strap.
I end... Feb 22 2014, 08:35 AM
Mike Bellis Bottom line... The relay is a high current switchi... Feb 22 2014, 08:40 AM
76-914 Relay, relay, relay. Clean everything till your he... Feb 22 2014, 09:10 AM
SLITS One other thing is that the current crop of switch... Feb 22 2014, 09:23 AM
bandjoey The first year I drove my 914 I had the problem. ... Feb 22 2014, 01:02 PM
bandjoey In the drawing above....The big fat wire from the ... Feb 22 2014, 01:07 PM
Luke M
In the drawing above....The big fat wire from the... Feb 22 2014, 01:49 PM
David Stowers
In the drawing above....The big fat wire from th... Feb 22 2014, 02:11 PM
type47 Any suggestions for novel/unique/cool ways to moun... Feb 22 2014, 03:52 PM
SLITS
Any suggestions for novel/unique/cool ways to mou... Feb 22 2014, 05:25 PM
ClayPerrine I tried all the different hot start fixes over the... Feb 23 2014, 10:00 AM
r_towle
Technically speaking, electrical current travels ... Feb 23 2014, 08:54 PM
toolguy In your first post, you said the lights go dim whe... Feb 23 2014, 03:43 PM
David Stowers
You can take the solenoid apart and clean up the ... Feb 23 2014, 04:35 PM
Spoke
the dash dim when I turn the key to start but the... Feb 23 2014, 08:44 PM
Tom A relay is not necessary, however, if one is not ... Feb 24 2014, 02:59 AM
Mark Henry Installing ford relays since the eighties. I'v... Feb 24 2014, 05:53 AM
stugray
That is not really true.
AC current moves across... Feb 24 2014, 08:21 AM
Tom The inductive spike is what makes the arc and carb... Feb 24 2014, 01:13 PM
timothy_nd28 Solid state relays is the way to go. :popcorn: Feb 24 2014, 01:21 PM
stugray Tom,
That is a pretty good explanation. The techn... Feb 24 2014, 02:28 PM
Tom stugray,
You are correct, I was trying not to g... Feb 24 2014, 06:22 PM
ClayPerrine I believe it and understand it. That's the sa... Feb 25 2014, 06:59 AM
Mark Henry
I believe it and understand it. That's the s... Feb 25 2014, 07:53 AM
Tom Clay,
A capacitor would not do the trick for th... Feb 25 2014, 07:58 AM
ClayPerrine
Clay,
A capacitor would not do the trick for t... Feb 25 2014, 10:28 AM
r_towle
Clay,
A capacitor would not do the trick for ... Feb 25 2014, 07:00 PM
McMark Very interesting! Thanks for posting. :notwo... Feb 25 2014, 10:22 AM
David Stowers Wow! This is what I love and hate about this s... Feb 25 2014, 04:03 PM
Mark Henry What :huh:
Your not going to solder in the capa... Feb 25 2014, 05:58 PM
Tom Well, I looked thru my limited left over parts and... Feb 25 2014, 06:27 PM
bandjoey With full light effects and adjustable power setti... Feb 25 2014, 07:01 PM
Mark Henry
With full light effects and adjustable power sett... Feb 25 2014, 07:11 PM
SLITS Nanu Nanu .................. Feb 25 2014, 08:24 PM
stugray You have to admit... installing the "helper... Feb 25 2014, 10:23 PM
Mark Henry
You have to admit... installing the "helper... Feb 26 2014, 07:06 AM
Tom Actually the normal state of the relay is open, an... Feb 26 2014, 09:03 AM
eyesright VW/Porsche built up a lot of good karma by bringin... Feb 26 2014, 09:58 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd October 2026 - 04:36 AM |
