Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Well I am a bit confused on this one. 2056 dual Webers. Electronic ignition. New SVDA dizzy. Rev limiting rotor.
Pulled the tank to install SS lines and had a few problems with crimping the lines when putting the tank back but I think I have that worked out. Compression good at 130 plus on all. Timing set at 30 BTDC. Car runs strong up to exactly 4400 rpm and then it sounds like it hits a wall. Can run it long and hard at rpms below so I am not thinking it is fuel limited. Swapped out the rev limiting rotor with standard one but same thing happens. I am going to pull the tank again to be sure on the lines. Any other thoughts? |
aircooledtechguy |
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest ![]() |
I would pull that new SVDA dizzy out and throw it as far as you possibly can. I've had 2 clients w/in the past week that have had these very things cause serious running issues. Just because it's "new" doesn't mean it works right. They are a total POS IMHO.
Find a good used German dizzy, clean it up, install new Bosch tune-up parts and install that. This may or may not be part of the problem, but it WILL become a problem in the near future. The problem is usually the LAST thing you installed. . . (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 19th July 2025 - 08:09 PM |
