| David Stowers |
Feb 22 2014, 05:06 AM
Member ![]() ![]() Group: Members Posts: 99 Joined: 28-June 12 From: UK Member No.: 14,613 Region Association: None |
On two occasions recently on pulling onto my driveway after a long journey my car won't restart after turning off to unlock the garage door. Luckily I can then just push the car in but with a European tour booked in the summer I'd like to sort the problem.
When I get back in after opening the garage the lights on the dash dim when I turn the key to start but there is no click. 20 minutes later it will start right up. Is this the problem that will be solved by a hot start relay kit or just a good old fashioned sticky solenoid? I'd rather do just the relay or just replace the solenoid so which is it? Thanks guys |
| stugray |
Feb 24 2014, 02:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Tom,
That is a pretty good explanation. The technical explanation is that the current through an inductor (starter solenoid) cannot change instantaneously. So when the switch is closed and ~35 Amps is flowing, then you open the switch (resistance goes to infinity), the current cannot stop flowing, so the voltage climbs to infinity to try to maintain the current flow until it reaches the breakdown voltage of the air gap (10,000 volts or better) before it arcs across. This is exactly how the points & coil make the spark jump the plug gap and the gap inside the rotor. The diode inside the relay in the picture above gives the current someplace to go so the voltage doesnt try to climb to keep the current flowing until it dissipates. QUOTE Solid state relays is the way to go. A SSR would work, but it has to be the kind that can allow "avalanche breakdown" to dissipate the Reverse EMF or it will fail quickly. (that just means it keeps flowing current even after told to turn off). The electronic ignition a lot of us use to replace the points is technically a SSR. |
David Stowers Starter relay or no starter relay Feb 22 2014, 05:06 AM
Mblizzard Sometimes it is hard for me to get my head around ... Feb 22 2014, 05:48 AM
SLITS Put the relay in and forget it.
Current Bosch reb... Feb 22 2014, 08:22 AM
Luke M Here's a quick wiring guide.
You should be abl... Feb 22 2014, 08:27 AM
r_towle Might try cleaning your tranny ground strap.
I end... Feb 22 2014, 08:35 AM
Mike Bellis Bottom line... The relay is a high current switchi... Feb 22 2014, 08:40 AM
76-914 Relay, relay, relay. Clean everything till your he... Feb 22 2014, 09:10 AM
SLITS One other thing is that the current crop of switch... Feb 22 2014, 09:23 AM
bandjoey The first year I drove my 914 I had the problem. ... Feb 22 2014, 01:02 PM
bandjoey In the drawing above....The big fat wire from the ... Feb 22 2014, 01:07 PM
Luke M
In the drawing above....The big fat wire from the... Feb 22 2014, 01:49 PM
David Stowers
In the drawing above....The big fat wire from th... Feb 22 2014, 02:11 PM
type47 Any suggestions for novel/unique/cool ways to moun... Feb 22 2014, 03:52 PM
SLITS
Any suggestions for novel/unique/cool ways to mou... Feb 22 2014, 05:25 PM
ClayPerrine I tried all the different hot start fixes over the... Feb 23 2014, 10:00 AM
toolguy Technically speaking, electrical current travels o... Feb 23 2014, 11:17 AM
David Stowers
Technically speaking, electrical current travels ... Feb 23 2014, 03:28 PM
r_towle
Technically speaking, electrical current travels ... Feb 23 2014, 08:54 PM
toolguy In your first post, you said the lights go dim whe... Feb 23 2014, 03:43 PM
David Stowers
You can take the solenoid apart and clean up the ... Feb 23 2014, 04:35 PM
Spoke
the dash dim when I turn the key to start but the... Feb 23 2014, 08:44 PM
Tom A relay is not necessary, however, if one is not ... Feb 24 2014, 02:59 AM
Mark Henry Installing ford relays since the eighties. I'v... Feb 24 2014, 05:53 AM
stugray
That is not really true.
AC current moves across... Feb 24 2014, 08:21 AM
Tom The inductive spike is what makes the arc and carb... Feb 24 2014, 01:13 PM
timothy_nd28 Solid state relays is the way to go. :popcorn: Feb 24 2014, 01:21 PM
Tom stugray,
You are correct, I was trying not to g... Feb 24 2014, 06:22 PM
ClayPerrine I believe it and understand it. That's the sa... Feb 25 2014, 06:59 AM
Mark Henry
I believe it and understand it. That's the s... Feb 25 2014, 07:53 AM
Tom Clay,
A capacitor would not do the trick for th... Feb 25 2014, 07:58 AM
ClayPerrine
Clay,
A capacitor would not do the trick for t... Feb 25 2014, 10:28 AM
r_towle
Clay,
A capacitor would not do the trick for ... Feb 25 2014, 07:00 PM
McMark Very interesting! Thanks for posting. :notwo... Feb 25 2014, 10:22 AM
David Stowers Wow! This is what I love and hate about this s... Feb 25 2014, 04:03 PM
Mark Henry What :huh:
Your not going to solder in the capa... Feb 25 2014, 05:58 PM
Tom Well, I looked thru my limited left over parts and... Feb 25 2014, 06:27 PM
bandjoey With full light effects and adjustable power setti... Feb 25 2014, 07:01 PM
Mark Henry
With full light effects and adjustable power sett... Feb 25 2014, 07:11 PM
SLITS Nanu Nanu .................. Feb 25 2014, 08:24 PM
stugray You have to admit... installing the "helper... Feb 25 2014, 10:23 PM
Mark Henry
You have to admit... installing the "helper... Feb 26 2014, 07:06 AM
Tom Actually the normal state of the relay is open, an... Feb 26 2014, 09:03 AM
eyesright VW/Porsche built up a lot of good karma by bringin... Feb 26 2014, 09:58 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd October 2026 - 04:37 AM |
