> Stalls out at 4400 RPM, Stumped!
Mblizzard
post Feb 23 2014, 08:09 PM
Well I am a bit confused on this one. 2056 dual Webers. Electronic ignition. New SVDA dizzy. Rev limiting rotor.
Pulled the tank to install SS lines and had a few problems with crimping the lines when putting the tank back but I think I have that worked out. Compression good at 130 plus on all. Timing set at 30 BTDC.
Car runs strong up to exactly 4400 rpm and then it sounds like it hits a wall. Can run it long and hard at rpms below so I am not thinking it is fuel limited. Swapped out the rev limiting rotor with standard one but same thing happens.
I am going to pull the tank again to be sure on the lines. Any other thoughts?
r_towle
post Feb 24 2014, 08:30 PM
Custom Member
Just so many things to go back through and verify at this point.
Do the basics....timing, valve adjustment, plugs, wires, cap etc.
Mblizzard
post Feb 24 2014, 08:48 PM
QUOTE(r_towle @ Feb 24 2014, 06:30 PM) *
Well while I may be a slow learner, I have picked check the basics up from all of the help I have received here. I set the valves when the engine was out. Checked them multiple times. Ran compression test all 135 plus. Timing is at 30 degrees. Plugs look good maybe a little rich but not bad. Wires are new and removing one at a time shows all are firing. Cap and rotor are new and not burnt. Carbs were not changed other adjusting after setting timing and balancing.
Won't get to work on it until Thursday. This work thing is a drag.
But it never hurts to be reminded to do the basics. That advice from those on this board has saved me a lot of grief. Regardless of what you think you know, that advice will always be sound.
So I have to look at the lines and filters or just dump it on Jakes door and hope he will fix it for free? Just have to get past that gate thing! Seriously at some point Jake will be doing the engine just got to save a few more dollars.
Mblizzard   Stalls out at 4400 RPM   Feb 23 2014, 08:09 PM
r_towle   Do you have an AFM? Did it do it before you change...   Feb 23 2014, 08:37 PM
Jake Raby   Sounds like you constricted something with the lin...   Feb 23 2014, 11:21 PM
Mblizzard   Had not thought about a line swap Jake. Did not ...   Feb 24 2014, 05:58 AM
stugray   Change back to the non-limiting rotor....   Feb 24 2014, 08:25 AM
Mike Bellis   I once had a fuel filter with an aluminum burr bal...   Feb 24 2014, 09:16 AM
rhodyguy   Mike, are you using the cb style pump with the met...   Feb 24 2014, 10:57 AM
Mblizzard   Mike, are you using the cb style pump with the me...   Feb 24 2014, 01:04 PM
aircooledtechguy   I would pull that new SVDA dizzy out and throw it ...   Feb 24 2014, 11:16 AM
Mblizzard   I would pull that new SVDA dizzy out and throw it...   Feb 24 2014, 01:33 PM
r_towle   I would pull that new SVDA dizzy out and throw i...   Feb 24 2014, 02:39 PM
Eric_Shea   :agree:   Feb 24 2014, 03:10 PM
r_towle   it "should" work either way...but the re...   Feb 24 2014, 04:02 PM
Racer Chris   I believe the return line is the one closest to t...   Feb 24 2014, 04:15 PM
r_towle   I believe the return line is the one closest to ...   Feb 24 2014, 05:05 PM
wndsnd   If you are running electronic cd ignition like the...   Feb 24 2014, 05:19 PM
Mblizzard   If you are running electronic cd ignition like th...   Feb 24 2014, 05:25 PM
wndsnd   :popcorn:   Feb 24 2014, 05:32 PM
rhodyguy   Do you still have your old 009?   Feb 24 2014, 06:46 PM
Mblizzard   Do you still have your old 009? I think the 1.8...   Feb 24 2014, 06:57 PM
r_towle   You never said if this was happening before you ch...   Feb 24 2014, 07:28 PM
Mblizzard   You never said if this was happening before you c...   Feb 24 2014, 07:41 PM
Jake Raby   Nate is spot on, too.. Trace your footsteps back. ...   Feb 24 2014, 07:35 PM
Jake Raby   Yep, a sheet metal screw was eaten. You'll mak...   Feb 24 2014, 08:18 PM
Mblizzard   Yep, a sheet metal screw was eaten. You'll ma...   Feb 24 2014, 08:36 PM
Jake Raby   Yep, a sheet metal screw was eaten. You'll m...   Feb 24 2014, 10:15 PM
wndsrfr   To separate fuel from spark issues here's a ne...   Feb 25 2014, 08:33 AM
r_towle   Just so many things to go back through and verify ...   Feb 24 2014, 08:30 PM
Mblizzard   Just so many things to go back through and verify...   Feb 24 2014, 08:48 PM
r_towle   Well it's fuel, air or timing. Narrow your sea...   Feb 24 2014, 08:53 PM
ThePaintedMan   Mike, After you have gone back through the basi...   Feb 25 2014, 08:17 AM
type47   It wouldn't be his 30 degree timing spec would...   Feb 25 2014, 04:17 PM
Mblizzard   It wouldn't be his 30 degree timing spec woul...   Feb 25 2014, 05:46 PM
zambezi   have you verified float levels?   Feb 25 2014, 05:54 PM
Mblizzard   have you verified float levels? I had the set a...   Feb 25 2014, 07:20 PM
- Lo-Fi Version Time is now: 19th July 2025 - 07:58 PM
