> Stalls out at 4400 RPM, Stumped!
Mblizzard
post Feb 23 2014, 08:09 PM
Well I am a bit confused on this one. 2056 dual Webers. Electronic ignition. New SVDA dizzy. Rev limiting rotor.
Pulled the tank to install SS lines and had a few problems with crimping the lines when putting the tank back but I think I have that worked out. Compression good at 130 plus on all. Timing set at 30 BTDC.
Car runs strong up to exactly 4400 rpm and then it sounds like it hits a wall. Can run it long and hard at rpms below so I am not thinking it is fuel limited. Swapped out the rev limiting rotor with standard one but same thing happens.
I am going to pull the tank again to be sure on the lines. Any other thoughts?
Jake Raby
post Feb 24 2014, 08:18 PM
Engine Surgeon
Yep, a sheet metal screw was eaten. You'll make that mistake once.
Mblizzard
post Feb 24 2014, 08:36 PM
QUOTE(Jake Raby @ Feb 24 2014, 06:18 PM) *
Yes I will never do it again. I was very lucky! You remember the painful lessons!
wndsrfr
post Feb 25 2014, 08:33 AM
To separate fuel from spark issues here's a neat easy way to do it.
Rev it with no load, sitting still in neutral. If it quits at 4400, it is ignition related since very little fuel flow is needed.
If it is quitting due to fuel restriction, it'll happen at even lower rpm if you power brake it and go wot in third gear, say. (IMG:style_emoticons/default/popcorn[1].gif)
Mblizzard   Stalls out at 4400 RPM   Feb 23 2014, 08:09 PM
r_towle   Do you have an AFM? Did it do it before you change...   Feb 23 2014, 08:37 PM
Jake Raby   Sounds like you constricted something with the lin...   Feb 23 2014, 11:21 PM
Mblizzard   Had not thought about a line swap Jake. Did not ...   Feb 24 2014, 05:58 AM
stugray   Change back to the non-limiting rotor....   Feb 24 2014, 08:25 AM
Mike Bellis   I once had a fuel filter with an aluminum burr bal...   Feb 24 2014, 09:16 AM
rhodyguy   Mike, are you using the cb style pump with the met...   Feb 24 2014, 10:57 AM
Mblizzard   Mike, are you using the cb style pump with the me...   Feb 24 2014, 01:04 PM
aircooledtechguy   I would pull that new SVDA dizzy out and throw it ...   Feb 24 2014, 11:16 AM
Mblizzard   I would pull that new SVDA dizzy out and throw it...   Feb 24 2014, 01:33 PM
r_towle   I would pull that new SVDA dizzy out and throw i...   Feb 24 2014, 02:39 PM
Eric_Shea   :agree:   Feb 24 2014, 03:10 PM
r_towle   it "should" work either way...but the re...   Feb 24 2014, 04:02 PM
Racer Chris   I believe the return line is the one closest to t...   Feb 24 2014, 04:15 PM
r_towle   I believe the return line is the one closest to ...   Feb 24 2014, 05:05 PM
wndsnd   If you are running electronic cd ignition like the...   Feb 24 2014, 05:19 PM
Mblizzard   If you are running electronic cd ignition like th...   Feb 24 2014, 05:25 PM
wndsnd   :popcorn:   Feb 24 2014, 05:32 PM
rhodyguy   Do you still have your old 009?   Feb 24 2014, 06:46 PM
Mblizzard   Do you still have your old 009? I think the 1.8...   Feb 24 2014, 06:57 PM
r_towle   You never said if this was happening before you ch...   Feb 24 2014, 07:28 PM
Mblizzard   You never said if this was happening before you c...   Feb 24 2014, 07:41 PM
Jake Raby   Nate is spot on, too.. Trace your footsteps back. ...   Feb 24 2014, 07:35 PM
Jake Raby   Yep, a sheet metal screw was eaten. You'll mak...   Feb 24 2014, 08:18 PM
Mblizzard   Yep, a sheet metal screw was eaten. You'll ma...   Feb 24 2014, 08:36 PM
Jake Raby   Yep, a sheet metal screw was eaten. You'll m...   Feb 24 2014, 10:15 PM
wndsrfr   To separate fuel from spark issues here's a ne...   Feb 25 2014, 08:33 AM
r_towle   Just so many things to go back through and verify ...   Feb 24 2014, 08:30 PM
Mblizzard   Just so many things to go back through and verify...   Feb 24 2014, 08:48 PM
r_towle   Well it's fuel, air or timing. Narrow your sea...   Feb 24 2014, 08:53 PM
ThePaintedMan   Mike, After you have gone back through the basi...   Feb 25 2014, 08:17 AM
type47   It wouldn't be his 30 degree timing spec would...   Feb 25 2014, 04:17 PM
Mblizzard   It wouldn't be his 30 degree timing spec woul...   Feb 25 2014, 05:46 PM
zambezi   have you verified float levels?   Feb 25 2014, 05:54 PM
Mblizzard   have you verified float levels? I had the set a...   Feb 25 2014, 07:20 PM
- Lo-Fi Version Time is now: 19th July 2025 - 08:12 PM
