Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Starting to do DFL (Dry Film Coating)
http://en.wikipedia.org/wiki/Dry_lubricant Ever pull apart an engine and you look at the bearings and say to yourself "those look good, I bet I could reuse them..." but you don't because the are stained or have the odd speck in them? Well these puppies are getting expensive and some are hard to find. For the most part you don't need expensive measuring tools to figure this out, you just need eyeballs and fingernails. If it has obvious physical damage, wear through, pitting, material missing or large scratches you can catch your fingernails on, then sorry you need new bearings. Minor scratches down the middle that you barely catch a nail on may be OK. Also look at the backs, loose bearings will "walk" scoring the back. Again stains are OK, physical damage is not. Also when you remove the bearing does it just fall out (not good) or does it still hold itself in the saddle (good sign) and you have to wiggle it out. On Porsche 911 I'd say 9 out of 10 of the #8 bearings can be reprocessed. Used main bearing set (IMG:http://www.914world.com/bbs2/uploads/post-26-1393378175.jpg) New full bearing set (IMG:http://www.914world.com/bbs2/uploads/post-26-1393428146.jpg) used intemediate bearings before (IMG:http://www.914world.com/bbs2/uploads/post-26-1393529753.jpg) after (IMG:http://www.914world.com/bbs2/uploads/post-26-1393529779.jpg) 3.2 set before, minor scratches, 3 deeper scratches but still within spec. before (IMG:http://www.914world.com/bbs2/uploads/post-26-1393530486.jpg) after (IMG:http://www.914world.com/bbs2/uploads/post-26-1393594831.jpg) Close up pic's of the 3 worst from that set (IMG:http://www.914world.com/bbs2/uploads/post-26-1393594792.jpg) Not offering this on type 4 bearings (except I will do the steel backed split middle) at this time. This may change once I test a process. Piston skirts and ceramic piston coatings coming soon. Inspect and process full 911 engine bearings set (main, #8, rod and intermediate bearings, new or used) $175 Turn around 2-3 days. |
Mark Henry |
Reprocessed #8 bearings, two are 3.0- and one is a 2.0-2.7
One of the 3.0 was within spec, but IMO a hair loose, the DFL slightly tightened up the tolerance. The DFL at the most adds .0005 (0.01mm) and this can reduced by polishing with a soft cloth. This takes a quite while to do, but is safer than using a green scotch bright pad. Top set of rod bearings are used 3.2 and the middle set are used 2.7 Attached image(s) ![]() |
Lo-Fi Version | Time is now: 17th July 2025 - 04:43 AM |
