> Apollo Racer Build Thread, Numeric 981 Shifter Upgrade, EZ36 to MS3 wiring diagrams
rnellums
post Sep 28 2011, 07:01 PM
Professional Enthusiast
I am starting this thread to document the build of my recent acquisition of a car I am going to name Apollo. It was previously owned by a fellow out in Illinois and was sold to me via 914 LTD. From what I know It was a purpose built Auto X car, but only has about two hours of run time on the engine.
Here are the specs as I received it:
Exterior Mods:
  • Factory Steel Flares
  • Newish Silver Base/Clear
  • Fiberglass 916 Style Front Bumper
  • Fiberglass Stock Style Rear Bumper
  • Fiberglass Hood With Headlight Delete
  • Fiberglass Trunk
  • Fiberglass Painted Rocker Panels
  • Painted Targa Top
  • Lexan Rear Window
  • Lightened Door Skins
  • Original Doors, Hood, Trunk
  • No Wipers, Headlights
  • Rear Porsche Reflector
Interior Mods:
  • Koenig Race Seats
  • RaceTech Leather Wheel
  • Amco Console with Assorted Gauges
  • Welt. Short Shift Kit
  • Bolt in Cage with Door Bars
  • Simpson 4 pt. Harnesses
Suspension Mods:
  • Rich Johnson 5-Lug Conversion
  • Front Volvo Big Brakes
  • Front Vented Rotors
  • 911 Front Struts
  • Koni Adjustable Shocks
  • 914-6 Rear Rotors With Stock Front Calipers
  • 22mm Front Torsion Bars
  • Welt. Adj. Front Sway
  • 180 lb Springs w/Adjustable Perches
  • Hoosier Road Race Radials
Engine Specifications:
  • Front Mounted Oil Cooler
  • 2.4 L 4-cyl built by ROCS auto
  • 103mm J+E Forged Pistons
  • 1.8L Stroked to 2.0 Specs
  • 48mm Intake
  • 38mm Exhaust
  • Chromoly Pushrods
  • High Flow Oil Pump
  • MSD Ignition w/ Adj. Rev. Limiter
  • 44mm Dual Webers
  • Lightened Flywheel
  • Kennedy Engineering Stage IV Clutch
  • Ported, Polished Heads with 10:1 Compression
  • Port Matched Manifolds
  • Kerry Hunter Headers
  • Claimed 180 HP
  • Claimed 170 ft-lbf Torque
Transmission Specs:
  • Recent Rebuild by 914 LTD
  • Quaffe Torque Bias Diff
  • Shortened 5th Gear
Misc:
  • 5 Gal Fuel Cell
  • New Bearings and Bushings
  • Blue Brake Fluid
  • 8x15 Fuchs
  • Claimed 1600 lb Weight
And Now the pictures!
post Mar 4 2014, 09:47 AM
That looks like the sch from an Outback. If so it was located on the back seat,left side and half way up by the antennae/stereo junction. I thought it was part of the stereo and looked like a small amp to me.
rnellums
post Mar 4 2014, 11:47 AM
QUOTE(76-914 @ Mar 4 2014, 08:47 AM) *
So my harness matches the diagrams above perfectly, I don't have a connector on the LH above the wheel well. Harness and engine are out of a 2001 legacy outback if that helps.
Scotty, I'm going to make a list of which connectors I cut and which I keep as I go.
post Mar 4 2014, 05:19 PM
QUOTE(rnellums @ Mar 4 2014, 09:47 AM) *
My mistake. I saw the hatchback lid and.....duh. Go with SVO's input then. I remember the pump being in the trunk behind the R seat. It will be close to the pump. BTW, do your homework before selling the copper scrap. A lot of hustlers in that trade.
rnellums
post Mar 4 2014, 10:43 PM
QUOTE(76-914 @ Mar 4 2014, 04:19 PM)
Now I'm all confused. I can seem to keep all the models straight. It came out of a 2001 H6 wagon. But I still don't have the connector.for the pump in the harness. Is it labeled in the wiring diagrams?
post Mar 5 2014, 05:32 PM
QUOTE(rnellums @ Mar 4 2014, 08:43 PM) *
First, I posted 2 pic's re: the controller and plug but listed them in my thread. (IMG:style_emoticons/default/chair.gif) IIRC 11 month's later, after the harness comes alongside the psg door it continues past the R back seat. At that point it split. Some of it continued to the back lift door, some of it went behind the R rear wheel well and onto some senders around the gas tank and the branch you want went directly behind the rear seat.Once it is behind the L rear seat it winds it way around and beneath the L rear seat and continues back to the psg side where it connects to the pump. The harness that the controller connects to is sheathed in grey and went from the harness behind the L rear seat then back about 2 feet and up about 1 foot off the floor. I think it is directly below the antennae junction on the L rear glass behind the L rear seat. But then again, I can't even remember what I ate for breakfast this morning. (IMG:style_emoticons/default/lol-2.gif) Kent
rnellums   Apollo Racer Build Thread   Sep 28 2011, 07:01 PM
rnellums   Exterior   Sep 28 2011, 07:05 PM
rnellums   Interior:   Sep 28 2011, 07:07 PM
rnellums   Suspension:   Sep 28 2011, 07:09 PM
rnellums   Engine:   Sep 28 2011, 07:11 PM
rnellums   Trunks:   Sep 28 2011, 07:13 PM
Cap'n Krusty   Nice car. I'm not up on current PCA classes, ...   Sep 28 2011, 07:25 PM
jcambo7   Drop a big 6 in it! :driving:   Sep 28 2011, 07:34 PM
rnellums   I think I may plan for a 2.7 build when the 2.4 ge...   Sep 28 2011, 07:36 PM
Cairo94507   With all that car I would plan for a 3.6 or 3.8 bu...   Sep 28 2011, 07:48 PM
tscrihfield   Ross, Nice Buy! Hopefully get to see it in pe...   Sep 28 2011, 08:42 PM
rnellums   I haven't pushed it past 3000 RPM yet since it...   Sep 28 2011, 08:49 PM
campbellcj   Nice car, congrats!!! I think the wei...   Sep 28 2011, 10:39 PM
campbellcj   dupe   Sep 28 2011, 10:39 PM
Racer Chris   Nice buy, lots of potential there. Do you know wha...   Sep 29 2011, 12:00 AM
Brett W   If you start doing much in the way of track events...   Sep 29 2011, 07:57 AM
mark21742   If you want it and end up out this way I have a st...   Sep 29 2011, 08:12 AM
rnellums   Your header is way too small for a 2.4L. I guaran...   Sep 29 2011, 10:24 AM
Racer Chris   I think I am at least going to keep the headers f...   Sep 29 2011, 11:05 AM
mark21742   Damn auto correct and me not paying attention........   Sep 29 2011, 10:36 AM
rnellums   It'll get ya. I realized that after I posted....   Sep 29 2011, 10:45 AM
rnellums   I just checked the engine build sheet. According ...   Sep 29 2011, 12:04 PM
Racer Chris   Kerry Hunter never made a 1 5/8" header. You ...   Sep 29 2011, 01:11 PM
gms   Very Nice, Congrats! See you in spring at driv...   Sep 29 2011, 02:57 PM
rnellums   Yeah, what do you run in?   Sep 29 2011, 03:20 PM
gms   Yeah, what do you run in? Midwest Council of Spo...   Sep 30 2011, 10:49 AM
rnellums   Yeah, what do you run in? Midwest Council of Sp...   Sep 30 2011, 12:16 PM
gms   The cage does have door bars, I'll just have ...   Sep 30 2011, 05:45 PM
Brett W   I don't know about SCCA vintage, but in HSR, i...   Sep 30 2011, 01:33 PM
rnellums   Looks like I better start looking out for an inexp...   Sep 30 2011, 02:16 PM
ChrisNPDrider   What class was it built for? :D If I were in your...   Sep 30 2011, 02:41 PM
brant   inexpensive and aluminum trailer, are not 2 words ...   Sep 30 2011, 02:47 PM
tscrihfield   inexpensive and aluminum trailer, are not 2 words...   Oct 5 2011, 06:54 PM
rnellums   The 16th I'll be in AR for MUSR, but the lappi...   Oct 3 2011, 10:23 AM
gms   The 16th I'll be in AR for MUSR, but the lapp...   Oct 4 2011, 09:19 AM
timgreen   If you have time come to Blackhawk Farms Raceway S...   Oct 5 2011, 09:08 AM
rnellums   If you have time come to Blackhawk Farms Raceway ...   Oct 5 2011, 09:39 AM
timgreen   If you have time come to Blackhawk Farms Raceway...   Oct 5 2011, 07:02 PM
rnellums   Both? As much as I can afford. I was passenger in ...   Oct 5 2011, 07:02 PM
rnellums   Is the best place to meet the tech inspection guys...   Oct 5 2011, 07:10 PM
timgreen   Is the best place to meet the tech inspection guy...   Oct 5 2011, 07:19 PM
rnellums   Trailering it up there seems like the best choice ...   Oct 5 2011, 07:34 PM
rnellums   My boss has an 18' trailer he'll give me f...   Oct 7 2011, 01:21 PM
timgreen   My boss has an 18' trailer he'll give me ...   Oct 8 2011, 05:27 PM
rnellums   Some photos from a car show on the Purdue Mall Stu...   Oct 8 2011, 03:21 PM
BigDBass   :popcorn:   Oct 8 2011, 06:50 PM
rnellums   I can make it street legal enough, but poor fuel e...   Oct 8 2011, 07:41 PM
rnellums   Its been a while since I put anything up here, but...   Mar 16 2012, 06:01 PM
gms   Its been a while since I put anything up here, bu...   Mar 16 2012, 06:58 PM
rnellums   Some fun photos of my first autocross. I came in ...   May 17 2012, 01:37 PM
gms   Some fun photos of my first autocross. I came in...   May 17 2012, 07:54 PM
rnellums   Wow! It has been a while since I have updated...   Feb 19 2014, 04:40 PM
rnellums   It's coming together!   Feb 19 2014, 04:43 PM
Chris H.   Sweeeeet! Looks like a nice clean engine to s...   Feb 19 2014, 05:26 PM
rnellums   Sweeeeet! Looks like a nice clean engine to ...   Feb 19 2014, 06:01 PM
brant   fun.... I want a ride when its finished   Feb 19 2014, 06:12 PM
rnellums   fun.... I want a ride when its finished I...   Feb 19 2014, 06:20 PM
rnellums   I spent some time tonight working on the 2nd subar...   Feb 19 2014, 10:04 PM
1stworks   :Qarl: Sweet!!!!!!...   Feb 20 2014, 08:23 AM
rnellums   Today my neighbor stopped by and dropped off an ol...   Feb 20 2014, 07:55 PM
76-914   Nice welds! Maybe you can flip that fan around...   Feb 21 2014, 06:40 PM
rnellums   Nice welds! Maybe you can flip that fan aroun...   Feb 22 2014, 12:05 AM
rnellums   I'm laying my plan out for the accessory belts...   Feb 22 2014, 12:01 AM
Gary   I'm laying my plan out for the accessory belt...   Feb 22 2014, 09:56 AM
rnellums   The 818 kit car guys have this option: alternato...   Feb 22 2014, 10:26 AM
76-914   I'm laying my plan out for the accessory bel...   Feb 22 2014, 11:18 AM
scotty b   I'm laying my plan out for the accessory belt...   Mar 4 2014, 09:09 AM
76-914   I'm laying my plan out for the accessory bel...   Mar 4 2014, 10:03 AM
skeates   Check out the Toyota MR2 Radiators. I got an after...   Feb 22 2014, 12:24 AM
76-914   :hijacked: Pls excuse the quick Hijack Ross but i...   Feb 22 2014, 09:41 AM
rnellums   I picked up a radiator from the Junkyard today for...   Feb 22 2014, 07:11 PM
914forme   Fans work better pulling air than pushing. I am a...   Feb 23 2014, 04:32 PM
rnellums   Fans work better pulling air than pushing. I am ...   Feb 23 2014, 04:49 PM
rnellums   I got a bit distracted last week while hanging out...   Mar 3 2014, 09:04 AM
76-914   I don't envy you sorting that maze out! Yo...   Mar 3 2014, 09:25 AM
rnellums   I finally got every connector flagged according to...   Mar 3 2014, 10:50 PM
76-914   Ross, is the pump controller in there? Shit, I jus...   Mar 3 2014, 11:37 PM
rnellums   Where would it have been in the car? I pulled the ...   Mar 3 2014, 11:38 PM
904svo   The fuel pump controller is located in the trunk, ...   Mar 4 2014, 08:18 AM
rnellums   The fuel pump controller is located in the trunk,...   Mar 4 2014, 08:47 AM
scotty b   Also if it helps you or anyone else, I have factor...   Mar 4 2014, 09:13 AM
76-914   That looks like the sch from an Outback. If so it ...   Mar 4 2014, 09:47 AM
rnellums   That looks like the sch from an Outback. If so it...   Mar 4 2014, 11:47 AM
76-914   That looks like the sch from an Outback. If so i...   Mar 4 2014, 05:19 PM
rnellums   My mistake. I saw the hatchback lid and.....duh. ...   Mar 4 2014, 10:43 PM
76-914   My mistake. I saw the hatchback lid and.....duh....   Mar 5 2014, 05:32 PM
Chris H.   On the radiator setup, you might want to look at P...   Mar 4 2014, 04:52 PM
scotty b   On the radiator setup, you might want to look at ...   Mar 4 2014, 07:48 PM
rnellums   On the radiator setup, you might want to look at ...   Mar 4 2014, 10:48 PM
Andyrew   On the radiator setup, you might want to look at ...   Mar 4 2014, 11:02 PM
rnellums   So this may sound like I am taking crazy pills Ken...   Mar 5 2014, 07:51 PM
rnellums   I am trying to get a couple more day of driving in...   Mar 6 2014, 08:51 AM
76-914   In your factory manual; is there a page in the wir...   Mar 6 2014, 09:11 AM
rnellums   In your factory manual; is there a page in the wi...   Mar 6 2014, 10:12 AM
76-914   Yup, looks like your right and I may have over tho...   Mar 6 2014, 10:29 AM
Chris H.   Yup, looks like your right and I may have over th...   Mar 6 2014, 05:35 PM
Chris H.   Double post! Dang ipad! :hissyfit:   Mar 6 2014, 05:45 PM
AE354803   [quote name='76-914' post='2006876' date='Ma...   Mar 6 2014, 07:17 PM
Chris H.   Great work man! I :beer2: Makes perfect sen...   Mar 7 2014, 10:07 AM
AE354803   Great work man! I :beer2: Makes perfect se...   Mar 7 2014, 11:35 AM
5 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 28th September 2026 - 11:47 PM
