Ctrout |
Member ![]() ![]() Group: Members Posts: 377 Joined: 20-May 04 From: Mountain Home, ID. Member No.: 2,091 ![]() |
Has anybody here tried to replace your oil cooler seals with the engine installed in the vehicle (a la pelican article)? The article is a little vague and I think I loosened the wrong bolt and now I may have to drop the engine just to tighten it again! (IMG:style_emoticons/default/headbang.gif) I loosened a 17mm bolt next to the oil filter and now it just spins. I think there is a nut behind it that I can't get to. Does anybody have a picture indicating the correct bolts (or nuts) to remove?
tommy914 |
Life is a journey, enjoy every turn. ![]() ![]() ![]() Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None ![]() |
You need to loosen these to get the oil cooler seals out.
They are not 17mm nuts. Not sure what you loosened. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 7th July 2025 - 08:05 AM |
