| SteveL |
Mar 13 2014, 03:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 666 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None
I hit the key, and she cranks the starter a bit slow for a couple of turns then dies out. Acts exactly like a low battery.
Battery is new (1 month old). The car has not been driven since the new battery was put in, but it was started several times, and allowed to run a while. At first it cranked over just fine as you would expect with a brand new battery. Last week, the slow crank and die started. Charged battery, same thing. Brought battery to Interstate, they tested it and said it was fine. Cleaned all major connections - battery post connections, trans ground strap, battery ground to body, battery cable connection at starter. No improvement. I do have a starter relay installed, it has been there for many years. Help Please! I stumped. |
| TheCabinetmaker |
Mar 13 2014, 08:55 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,358 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Jumper cables won't do it. You need a large wire fastened securely. remove and clean the starter connections. Then remove starter an take it to a local starter repair ship
SteveL Slow Crank Mar 13 2014, 03:49 PM
dlee6204 Have you checked to see if your alternator is char... Mar 13 2014, 03:59 PM
SirAndy Check your tranny ground strap ...
:shades2:
EDI... Mar 13 2014, 03:59 PM
SteveL
:shades2:
ED... Mar 13 2014, 04:12 PM
Dave_Darling You still have bad connections somewhere.
Try run... Mar 13 2014, 05:46 PM
Cap'n Krusty Might wanna have an amp draw test done on the car.... Mar 13 2014, 06:37 PM
SteveL OK - I used heavy duty jumper cables. Body of sta... Mar 13 2014, 08:47 PM
r_towle Starter
It lasted 40 years, be happy. Mar 13 2014, 08:50 PM
sfrenck
Starter
:agree:... Mar 14 2014, 11:24 AM
WLD419 It seems like something binding or startermotor is... Mar 14 2014, 05:37 AM
Tom Sounds like the starter may be going bad. The brus... Mar 14 2014, 11:52 AM
ConeDodger Jack up the oil fill plug on the top of the motor ... Mar 14 2014, 11:56 AM
stugray
That is difficult to do as most of the current m... Mar 14 2014, 03:52 PM
SteveL I pulled the starter.
NAPA said they had a Bosch S... Mar 14 2014, 04:42 PM
Dave_Darling
NAPA said they had a Bosch SR17x in stock. Went ... Mar 14 2014, 06:23 PM
stugray I bought the high torque starter on ebay.
Seems t... Mar 14 2014, 05:03 PM
SteveL Put in new starter, and it cranks faster than I ca... Mar 25 2014, 07:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th December 2025 - 08:01 AM |
