Fuel Pump 2 seconds, Fuel Pump voltage |
thompson-mfr |
Mar 14 2014, 12:40 PM
Thompson, Ryan Group: Members Posts: 198 Joined: 30-September 08 From: Silverton, OR Member No.: 9,598 Region Association: Pacific Northwest |
I have a 74 2.0L original FI and the fuel pump has been moved to the front trunk. I converted to the in and out style (75-76).
My fuel pump used to go on for 2 seconds to prime, then off until cranking or running. I know this is how it is supposed to work. Mine now is on constant with the key in aux position (before starting/cranking or running) What controls this? The computer? I also have only 7 volts to the pump and 9 volts at the fuse on the relay board that pump power goes through. Good 12+ volts at battery. Finally to the question: Does the computer control this 2 second prime? |
76-914 |
Mar 14 2014, 02:19 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
What size wire did you run to the pump? That's quite a drop in voltage!
Lo-Fi Version | Time is now: 1st June 2024 - 09:31 PM |
