> Slow Crank, Diagnostic Advice?
SteveL
post Mar 13 2014, 03:49 PM
I hit the key, and she cranks the starter a bit slow for a couple of turns then dies out. Acts exactly like a low battery.
Battery is new (1 month old). The car has not been driven since the new battery was put in, but it was started several times, and allowed to run a while. At first it cranked over just fine as you would expect with a brand new battery.
Last week, the slow crank and die started. Charged battery, same thing. Brought battery to Interstate, they tested it and said it was fine. Cleaned all major connections - battery post connections, trans ground strap, battery ground to body, battery cable connection at starter. No improvement.
I do have a starter relay installed, it has been there for many years.
Help Please! I stumped.
SteveL
post Mar 14 2014, 04:42 PM
I pulled the starter.
NAPA said they had a Bosch SR17x in stock. Went to pick it up, and it is the SR15x. All the books say it is a compatible replacement, but it is a LOT smaller.
All other local places have rebuild versions of the Sr15x too.
Anybody know anything about them? Will it work? Is is weaker?
SteveL   Slow Crank   Mar 13 2014, 03:49 PM
dlee6204   Have you checked to see if your alternator is char...   Mar 13 2014, 03:59 PM
SirAndy   Check your tranny ground strap ... :shades2: EDI...   Mar 13 2014, 03:59 PM
SteveL   Check your tranny ground strap ... :shades2: ED...   Mar 13 2014, 04:12 PM
Dave_Darling   You still have bad connections somewhere. Try run...   Mar 13 2014, 05:46 PM
Cap'n Krusty   Might wanna have an amp draw test done on the car....   Mar 13 2014, 06:37 PM
SteveL   OK - I used heavy duty jumper cables. Body of sta...   Mar 13 2014, 08:47 PM
r_towle   Starter It lasted 40 years, be happy.   Mar 13 2014, 08:50 PM
sfrenck   Starter It lasted 40 years, be happy. :agree:...   Mar 14 2014, 11:24 AM
The Cabinetmaker   Jumper cables won't do it. You need a large wi...   Mar 13 2014, 08:55 PM
WLD419   It seems like something binding or startermotor is...   Mar 14 2014, 05:37 AM
Tom   Sounds like the starter may be going bad. The brus...   Mar 14 2014, 11:52 AM
ConeDodger   Jack up the oil fill plug on the top of the motor ...   Mar 14 2014, 11:56 AM
stugray   That is difficult to do as most of the current m...   Mar 14 2014, 03:52 PM
SteveL   I pulled the starter. NAPA said they had a Bosch S...   Mar 14 2014, 04:42 PM
Dave_Darling   NAPA said they had a Bosch SR17x in stock. Went ...   Mar 14 2014, 06:23 PM
stugray   I bought the high torque starter on ebay. Seems t...   Mar 14 2014, 05:03 PM
SteveL   Put in new starter, and it cranks faster than I ca...   Mar 25 2014, 07:00 AM
- Lo-Fi Version Time is now: 10th December 2025 - 08:01 AM
