914 Engine Drop |
914 Engine Drop |
'72914guy |
Mar 14 2014, 09:54 PM
Newbie Group: Members Posts: 10 Joined: 26-April 08 From: SoCal Member No.: 8,969 Region Association: Southern California |
Hello all, I hope you are doing well.
I had a question regarding dropping the engine. I have a 1972 914-4 1.7L. Is it possible to separate the engine from the trans before dropping it so that I don't have to drop the trans as well? I looked at the article on the pelican forums and it only shows the procedure dropping the engine in tandem with the trans. Some Google searching yielded no good results either... and I'd rather not mess with the CV joints. Thanks in advance for the help! |
JamesM |
Mar 14 2014, 10:08 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Its pretty easy to pull the trans while leaving the engine in, never seen someone try to do it the other way. Would probably be more trouble then it is worth as without the engine the trans would pretty much fall on the floor anyways.
Lo-Fi Version | Time is now: 9th June 2024 - 08:07 AM |
