> A vapor lock issue?, Starting after 30 minutes or so of sitting
boxsterfan
post Mar 17 2014, 10:23 AM
914's are kewl
So on my 74 2.0L D-Jet, my car normally behaves this way on cold start:
1. Starts right up and idles high while cold
2. As it gets warmed up, the idle "hunts" between 0 RPM and 1200 RPM and can occasionally die when pulling up to a stop sign (you might have to blip the throttle).
3. After she warms up, she idles perfect at 900-950 RPM.
The problem:
1. Car is warmed up driving to a store (idling perfect 900-950 RPM)
2. Go into store for 30 minutes
3. Start car (starts for a second but then dies if you didn't give it any gas)
4. Turn key off
5. Turn key right back on and it doesn't want to start (just cranks). But if you give it gas while cranking you can get her to start....almost like push starting the motor and popping clutch).
Note: My fuel pump is in the front. Stainless steel lines in the tunnel.
Am I still experience vapor lock?
Failing CHTS (also related to idle hunting)
Other?
Cap'n Krusty
post Mar 17 2014, 10:08 PM
Cap'n Krusty
Listen up! I'm old enough to have worked at a dealership when these cars were new. I did pre-delivery inspections, services, warranty work, and even major engine repairs on these cars. Lotsa test drives. 2 liter 914s ALL did this from the get-go. Every one of 'em. Floor the pedal, let it off as seems prudent. The FI guys at the Porsche training center were well aware of it, and attributed it to what they called "an electronic lie". The rather dumb analog control unit was unable to prioritize signals, and couldn't allow for heat soak, ambient air temps, and many other factors that are a piece 'o cake for next-gen and later systems. That's also why we sometimes had to unplug the TS1 in the plenum in order to make them run right.
The Cap'n
JawjaPorsche
post Mar 18 2014, 05:42 AM
QUOTE(Cap'n Krusty @ Mar 18 2014, 12:08 AM) *
The Cap'n
Just curious, Cap'n. Was this "An Electronic Lie' only related to the 2.0 or did the 1.7 have the same issues? (IMG:style_emoticons/default/popcorn[1].gif)
boxsterfan   A vapor lock issue?   Mar 17 2014, 10:23 AM
JawjaPorsche   Doesn't sound like vapor lock. Vapor locks us...   Mar 17 2014, 10:41 AM
The Cabinetmaker   If it's flooding and it starts by holding peda...   Mar 17 2014, 04:09 PM
boxsterfan   If it's flooding and it starts by holding ped...   Mar 17 2014, 09:38 PM
JamesM   I have a theory on this problem on both d-jet and ...   Mar 17 2014, 07:00 PM
boxsterfan   I have a theory on this problem on both d-jet and...   Mar 17 2014, 09:36 PM
tumamilhem   I am having a similar problem. My car was gone thr...   Mar 17 2014, 07:43 PM
Cap'n Krusty   Listen up! I'm old enough to have worked ...   Mar 17 2014, 10:08 PM
JawjaPorsche   Listen up! I'm old enough to have worked...   Mar 18 2014, 05:42 AM
boxsterfan   Listen up! I'm old enough to have worked...   Mar 18 2014, 10:53 AM
ky914porsche   Listen up! I'm old enough to have worke...   Jun 28 2014, 03:49 PM
The Cabinetmaker   Ky914, replace the gas pedal. It's the socket ...   Jun 29 2014, 05:23 AM
Cap'n Krusty   I don't recall it being a problem with the 1.7...   Mar 18 2014, 09:21 AM
cary   Cap'n will have to give you the details. But a...   Jun 28 2014, 07:30 PM
Tom   From the owner's manual for the 75 2.0 : B...   Jun 29 2014, 02:04 AM
swooshdave   The cylinder heads are aluminum and cool off at a...   Jun 29 2014, 07:18 AM
76-914   The cylinder heads are aluminum and cool off at ...   Jun 29 2014, 08:14 AM
Tom   The thermal conductivity of aluminum is about thre...   Jun 29 2014, 08:59 AM
- Lo-Fi Version Time is now: 23rd July 2026 - 03:35 AM
