| boxsterfan |
Mar 17 2014, 10:23 AM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
So on my 74 2.0L D-Jet, my car normally behaves this way on cold start:
1. Starts right up and idles high while cold 2. As it gets warmed up, the idle "hunts" between 0 RPM and 1200 RPM and can occasionally die when pulling up to a stop sign (you might have to blip the throttle). 3. After she warms up, she idles perfect at 900-950 RPM. The problem: 1. Car is warmed up driving to a store (idling perfect 900-950 RPM) 2. Go into store for 30 minutes 3. Start car (starts for a second but then dies if you didn't give it any gas) 4. Turn key off 5. Turn key right back on and it doesn't want to start (just cranks). But if you give it gas while cranking you can get her to start....almost like push starting the motor and popping clutch). Note: My fuel pump is in the front. Stainless steel lines in the tunnel. Am I still experience vapor lock? Failing CHTS (also related to idle hunting) Other? |
| Cap'n Krusty |
Mar 18 2014, 09:21 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I don't recall it being a problem with the 1.7s, but we had far more 2 liter cars on the sales lot than 1.7s.
The Cap'n |
boxsterfan A vapor lock issue? Mar 17 2014, 10:23 AM
JawjaPorsche Doesn't sound like vapor lock. Vapor locks us... Mar 17 2014, 10:41 AM
The Cabinetmaker If it's flooding and it starts by holding peda... Mar 17 2014, 04:09 PM
boxsterfan
If it's flooding and it starts by holding ped... Mar 17 2014, 09:38 PM
JamesM I have a theory on this problem on both d-jet and ... Mar 17 2014, 07:00 PM
boxsterfan
I have a theory on this problem on both d-jet and... Mar 17 2014, 09:36 PM
tumamilhem I am having a similar problem. My car was gone thr... Mar 17 2014, 07:43 PM
Cap'n Krusty Listen up! I'm old enough to have worked ... Mar 17 2014, 10:08 PM
JawjaPorsche
Listen up! I'm old enough to have worked... Mar 18 2014, 05:42 AM
boxsterfan
Listen up! I'm old enough to have worked... Mar 18 2014, 10:53 AM
ky914porsche
Listen up! I'm old enough to have worke... Jun 28 2014, 03:49 PM
The Cabinetmaker Ky914, replace the gas pedal. It's the socket ... Jun 29 2014, 05:23 AM
cary Cap'n will have to give you the details.
But a... Jun 28 2014, 07:30 PM
Tom From the owner's manual for the 75 2.0 :
B... Jun 29 2014, 02:04 AM
swooshdave
The cylinder heads are aluminum and cool off at a... Jun 29 2014, 07:18 AM
76-914
The cylinder heads are aluminum and cool off at ... Jun 29 2014, 08:14 AM
Tom The thermal conductivity of aluminum is about thre... Jun 29 2014, 08:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd July 2026 - 03:35 AM |
