Clean your grounding points, What a great F ing idea! NOT! |
Ctrout |
Aug 7 2004, 04:30 PM
Member Group: Members Posts: 377 Joined: 20-May 04 From: Mountain Home, ID. Member No.: 2,091 |
So i decided that the car is running well enough that I can start getting to some of the more minor maintenance needs. Time to clean the ground points right? Start with the easiest ones first. I go for the negative battery cable. The ground point stud is rather rusty so I hit it with some WD-40. I start loosening the nut and then it tightens up as I turn it. I change direction and tighten the nut back up, add more WD-40 and start again. I turn the nut, it gets difficult again, then the stud snaps off! Anyone want to buy a 914 cheap? Doesn't start at the moment but I promise it runs (for a while). So what now? Looks like I have to cut a hole through the sail panel to replace the stud. Anyone ever done this before? I swear I have never had such trouble with a car before in my life! Glad I didn't decide to replace vacuum lines, the engine probably would have exploded.
Brad Roberts |
Aug 7 2004, 11:36 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Use a lock washer under the ground cable so it digs into the sheet metal.
B |
Lo-Fi Version | Time is now: 13th June 2024 - 05:13 PM |
