DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,828 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
couple questions and looking for guidance on solution-
currently here is what is on the car - Rear: has new sport bilistien shocks and new 100# springs. spring perches are set right in the middle currently, 4th from the bottom, i think there are 3 more slots above that. Front: i have no idea- stock shocks etc, seem fine and no need to change them out. have not check to see if ride height etc is where it should be. I just completed putting all new 5 lug on front and back, with new calipers, brake lines, bearings etc etc., but now am going to put new turbo tie rods on. Once this is complete i was going to take it to local shop to have alignment done. They are fully familar with all older 911 air cooled , owner has a bunch of his own, so i guess he should be familar with the adjusting proceedure for the height balance? - i could move the rear spring perches up one or two spots but then it may make it a bit bouncy-more spring than shock. anyway any advice and direction also for threads that show how to measure these things would be helpful. Attached thumbnail(s) ![]() |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,059 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) Looks fine as is but you can level it easily. As mentioned before if you do it yourself count the turns on the adjuster screws, do them evenly, and do one turn at a time and "bounce" the front shocks a bit then drive it around before you do the next turn. I got mine a little too low up front at first.
Lowering it 1/2" probably won't cause bump steer. Mine came down a lot more than that. |
Lo-Fi Version | Time is now: 3rd July 2025 - 03:49 PM |
