| boxsterfan |
Mar 24 2014, 09:38 AM
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
My thermostat cable needs replaced. It's all frayed and messed up at the end where it connects top side. Right now, it's not connected and my flaps are in default wide open status.
So, looking at Pelican (part# 021-119-751-OEM), I see these for $41.75. Any alternatives here for this part? Something from a bike shop perhaps? And how hard to replace this with the engine in the car? |
| ThePaintedMan |
Mar 24 2014, 09:46 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
Dude... for real? Why not consolidate your questions to one post, rather than flooding us with three of them at once.
You can have a local bike shop make you a cable for the thermostat for $5 or less. The clutch cable from Pelican works well. All clutch cables wear out over time. Replace it. |
| boxsterfan |
Mar 24 2014, 10:20 AM
Dude... for real? Why not consolidate your questions to one post, rather than flooding us with three of them at once. You can have a local bike shop make you a cable for the thermostat for $5 or less. The clutch cable from Pelican works well. All clutch cables wear out over time. Replace it. Thanks for the reply. I broke my questions up because I find it easier to locate the topic later. And sometimes, all of these extra questions get lost in the shuffle. My bad. |
| eyesright |
Mar 24 2014, 10:49 AM
Member ![]() ![]() Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
You can have a local bike shop make you a cable for the thermostat for $5 or less. Yeah, go to the bike shop or maybe even Walmart. I just bought a standard length of cable. I wondered if it would cut cleanly with out fraying with regualr wire cutters...no problem. And I'd sugggest cutting it a couple of inches long! I replaced my good/functional cable just because it was short and hard to connect to the cooling flaps rod. Its a LOT easier to connect with an inch or two to hold on to with vise grips while you tighten the holding screw with the flaps closed against the springs. |
| boxsterfan |
Mar 24 2014, 11:04 AM
You can have a local bike shop make you a cable for the thermostat for $5 or less. Yeah, go to the bike shop or maybe even Walmart. I just bought a standard length of cable. I wondered if it would cut cleanly with out fraying with regualr wire cutters...no problem. And I'd sugggest cutting it a couple of inches long! I replaced my good/functional cable just because it was short and hard to connect to the cooling flaps rod. Its a LOT easier to connect with an inch or two to hold on to with vise grips while you tighten the holding screw with the flaps closed against the springs. What's the length of the cable? 2 feet? 2.5 feet? |
| AE354803 |
Mar 24 2014, 11:08 AM
Member ![]() ![]() Group: Members Posts: 238 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California |
You can have a local bike shop make you a cable for the thermostat for $5 or less. Yeah, go to the bike shop or maybe even Walmart. I just bought a standard length of cable. I wondered if it would cut cleanly with out fraying with regualr wire cutters...no problem. And I'd sugggest cutting it a couple of inches long! I replaced my good/functional cable just because it was short and hard to connect to the cooling flaps rod. Its a LOT easier to connect with an inch or two to hold on to with vise grips while you tighten the holding screw with the flaps closed against the springs. What's the length of the cable? 2 feet? 2.5 feet? I made mine using some a few feet of cable and some ferriles from the hardware store. Installed it and adjusted it, THEN cut it to length once it is installed properly. You can even crimp a ferrule tight up against the flap pinch point so that it will hold if the screw loosens a bit. See link below. http://www.914world.com/bbs2/index.php?sho...hermostat+cable |
boxsterfan Thermostat cable Mar 24 2014, 09:38 AM
malcolm2
[quote name='ThePaintedMan' post='2015210' date='... Mar 24 2014, 11:18 AM
Elliot Cannon
Dude... for real? Why not consolidate your questi... Mar 24 2014, 12:21 PM
ThePaintedMan
Dude... for real? :shades2: The reason for this... Mar 24 2014, 01:05 PM
boxsterfan
Dude... for real? :shades2: The reason for thi... Mar 24 2014, 01:35 PM
ThePaintedMan
Anyway, happy motoring and cheers! :beer2:
... Mar 24 2014, 01:51 PM
OU8AVW
... Mar 24 2014, 02:41 PM
mepstein They are a stock derailur cable. $5 or less Mar 24 2014, 10:10 AM
ripper911 Also, by breaking it up into seperate questions, p... Mar 24 2014, 10:47 AM
JawjaPorsche When you say thermostat cable, I assume you are ta... Mar 24 2014, 11:24 AM
Highland I found a couple for less money at these sites:
h... Mar 24 2014, 11:31 AM
brant Something must have changed recently with the supp... Mar 24 2014, 11:36 AM
malcolm2 awesomePOWDERCOAT.com
They will sell you a T-stat... Mar 24 2014, 12:47 PM
Jerlle I went down to the local REI bike shop and bought ... Mar 24 2014, 02:04 PM
mepstein If you pop for a high end cable, they are ss. Migh... Mar 24 2014, 03:51 PM
ripper911 I think we have people talking about two different... Mar 24 2014, 03:53 PM
The Cabinetmaker My two cents on the off topic chatter. Post as man... Mar 25 2014, 06:30 AM
ThePaintedMan Not useless Curt. I hadn't thought of it that ... Mar 25 2014, 06:57 AM
hndyhrr I got a t-stat cable at the bike shop kevlar coate... Mar 25 2014, 10:16 AM
boxsterfan So, I found an older derailleur cable I had from m... Mar 31 2014, 09:38 AM
hndyhrr I straighten out a coat hanger and put it thru fro... Mar 31 2014, 09:51 AM
rhodyguy boxsterfan, if the existing thermostat cable is st... Mar 31 2014, 11:43 AM
boxsterfan Got my thermostat cable replaced today with a old ... Apr 5 2014, 07:38 PM
Rand Wow, too much PMS on this thread. Truth though, re... Apr 5 2014, 07:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:03 PM |
