76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,737 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I've welded up a few small holes (< 5mm) in some obscure areas but now I'm thinking about closing the "wart holes" where the side turn lamps reside and I'm looking for a little guidance. Is it best to weld in a plug of similar thickness doing a little at a time to avoid warping? Also, I plan to add OEM side mirrors once I have "Little Frankie" running and I expect I shall find some holes that need to be filled when I do. Can I just use a backer plate and MIG these w/o fear of warping this area. TIA, Kent
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
cut a plug. Butt weld it in. A backer is fine on the mirror if you can get it inside. I usually do it without any backer. .023 wire and a little heat and it is fine. Little to no warpage
76-914 |
cut a plug. Butt weld it in. A backer is fine on the mirror if you can get it inside. I usually do it without any backer. .023 wire and a little heat and it is fine. Little to no warpage Scotty, what is the advantage of .023 over .030 in this instance? Is it related to the ga. of the metal or puddle area or what? To tell the truth I would have welded with the .030 had you not spoke up. (IMG:style_emoticons/default/pray.gif) BTW, nice work on the flared, blue car you just shot. |
Lo-Fi Version | Time is now: 10th July 2025 - 11:30 PM |
