> Closing up Body Holes, a welding question
76-914
post Mar 24 2014, 01:28 PM
I've welded up a few small holes (< 5mm) in some obscure areas but now I'm thinking about closing the "wart holes" where the side turn lamps reside and I'm looking for a little guidance. Is it best to weld in a plug of similar thickness doing a little at a time to avoid warping? Also, I plan to add OEM side mirrors once I have "Little Frankie" running and I expect I shall find some holes that need to be filled when I do. Can I just use a backer plate and MIG these w/o fear of warping this area. TIA, Kent
scotty b
post Mar 24 2014, 02:42 PM
rust free you say ?
cut a plug. Butt weld it in. A backer is fine on the mirror if you can get it inside. I usually do it without any backer. .023 wire and a little heat and it is fine. Little to no warpage
post Mar 24 2014, 02:56 PM
QUOTE(scotty b @ Mar 24 2014, 01:42 PM) *
Scotty, what is the advantage of .023 over .030 in this instance? Is it related to the ga. of the metal or puddle area or what? To tell the truth I would have welded with the .030 had you not spoke up. (IMG:style_emoticons/default/pray.gif) BTW, nice work on the flared, blue car you just shot.
scotty b
post Mar 24 2014, 04:24 PM
rust free you say ?
QUOTE(76-914 @ Mar 24 2014, 12:56 PM) *
Just less heat and you can make the gap a little tighter. I used to use .030 all the time as none of the local shops carried .023. After I special ordered 2 rolls they have been keeping a few in stock (IMG:style_emoticons/default/confused24.gif)
- Lo-Fi Version Time is now: 11th July 2025 - 03:09 AM
