Monday, 11 August 2025 |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,842 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
couple questions and looking for guidance on solution-
currently here is what is on the car - Rear: has new sport bilistien shocks and new 100# springs. spring perches are set right in the middle currently, 4th from the bottom, i think there are 3 more slots above that. Front: i have no idea- stock shocks etc, seem fine and no need to change them out. have not check to see if ride height etc is where it should be. I just completed putting all new 5 lug on front and back, with new calipers, brake lines, bearings etc etc., but now am going to put new turbo tie rods on. Once this is complete i was going to take it to local shop to have alignment done. They are fully familar with all older 911 air cooled , owner has a bunch of his own, so i guess he should be familar with the adjusting proceedure for the height balance? - i could move the rear spring perches up one or two spots but then it may make it a bit bouncy-more spring than shock. anyway any advice and direction also for threads that show how to measure these things would be helpful. Attached thumbnail(s) ![]() |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
I did a 1/2 inch rake down on the front, measured from the donuts I think. I also put a couple hundred pounds of weight in the drivers seat when I did this.
DRPHIL914 |
Lo-Fi Version | Time is now: 10th August 2025 - 08:37 PM |
