> Ride height and front to back balance, Rear currently sits about 1/2-3/4" lower than front
DRPHIL914
post Mar 20 2014, 07:17 AM
Dr. Phil
couple questions and looking for guidance on solution-
currently here is what is on the car -
Rear: has new sport bilistien shocks and new 100# springs. spring perches are set right in the middle currently, 4th from the bottom, i think there are 3 more slots above that.
Front: i have no idea- stock shocks etc, seem fine and no need to change them out. have not check to see if ride height etc is where it should be.
I just completed putting all new 5 lug on front and back, with new calipers, brake lines, bearings etc etc., but now am going to put new turbo tie rods on. Once this is complete i was going to take it to local shop to have alignment done. They are fully familar with all older 911 air cooled , owner has a bunch of his own, so i guess he should be familar with the adjusting proceedure for the height balance?
- i could move the rear spring perches up one or two spots but then it may make it a bit bouncy-more spring than shock.
anyway any advice and direction also for threads that show how to measure these things would be helpful.
bandjoey
post Mar 24 2014, 09:01 PM
bandjoey
To lower the front...Looking at the bolt head on....Clockwise or Counterclockwise turns? Thanks for the buttin-in questions! (IMG:style_emoticons/default/biggrin.gif)
Philip W.   Ride height and front to back balance   Mar 20 2014, 07:17 AM
monkeyboy   A corner balance\height adjustment has nothin...   Mar 20 2014, 09:32 AM
mittelmotor   Are you measuring ride height from the bottom edge...   Mar 20 2014, 10:01 AM
malcolm2   Are you measuring ride height from the bottom edg...   Mar 24 2014, 11:07 AM
Chris H.   A pic would help but what you're describing so...   Mar 20 2014, 10:54 AM
Philip W.   A pic would help but what you're describing s...   Mar 20 2014, 12:33 PM
bulitt   Been a while but I think I read (in haynes?) or th...   Mar 20 2014, 11:58 AM
Philip W.   Been a while but I think I read (in haynes?) or t...   Mar 20 2014, 12:29 PM
914_teener   Been a while but I think I read (in haynes?) or t...   Mar 20 2014, 01:10 PM
Philip W.   Finally took a picture. Pretty close to stock. Whe...   Mar 24 2014, 09:51 AM
mittelmotor   Finally took a picture. Pretty close to stock. Wh...   Mar 24 2014, 10:06 AM
Chris H.   :agree: Looks fine as is but you can level it eas...   Mar 24 2014, 10:55 AM
Philip W.   :agree: Looks fine as is but you can level it ea...   Mar 24 2014, 11:15 AM
Travis Neff   I did a 1/2 inch rake down on the front, measured ...   Mar 24 2014, 12:52 PM
Philip W.   I did a 1/2 inch rake down on the front, measured...   Mar 24 2014, 08:13 PM
bandjoey   To lower the front...Looking at the bolt head on.....   Mar 24 2014, 09:01 PM
jcd914   To lower the front...Looking at the bolt head on....   Mar 25 2014, 01:02 AM
- Lo-Fi Version Time is now: 3rd July 2025 - 03:42 PM
