| 76-914 |
Apr 6 2014, 06:33 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,991 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I'm going to have several electrical questions. 1st, Is pin #8, on the 14 pin plug at the relay board, the only switched 12v+ source in the engine compartment? TIA, Kent
| Tom |
Apr 7 2014, 11:37 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Kent,
Don't know why as they don't draw that much. Is the Subie ECU controlling them? If so, that feature may already be in place inside the ECU because Subaru found it to be an issue, but I don't know for sure. If you found it to be a problem, it wouldn't be that hard to remedy. A 30 amp relay wired for the starter circuit to open the fan circuit. Basically the fan power to 30, ground to 85, fan energized to 87A (NC contact), and starter power from the key switch to 86. Whenever the starter circuit is energized, the relay opens and fans have no power. Stop starting, power to fans is back. I think this would mostly depend on how much current the fans draw if the engine is hot and both are running to cool it. Say you drive 15 miles to the store and are inside 5 min and come back out. Would the fans still be running? This would also be determined on the battery condition and CCA. A battery with 500CCA will give 30 seconds of cranking at a big amperage without falling below a certain percentage of battery voltage. So if the starter is drawing 120 amps and fans 30 amps, that should not be a problem unless the battery is on the way out. Tom EDIT: Cold cranking amperes (CCA) is the amount of current a battery can provide at 0 °F (−18 °C). The rating is defined as the current a lead-acid battery at that temperature can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12-volt battery). It is a more demanding test than those at higher temperatures. This is the most widely used cranking measurement for comparison purposes. |
76-914 Electrical Question #15 Need Help Please Apr 6 2014, 06:33 PM
Mike Bellis
I'm going to have several electrical question... Apr 6 2014, 07:38 PM
Jeff Bowlsby Careful, not all model years are the same. Check ... Apr 6 2014, 09:48 PM
Tom I checked all of the schematics I can find and all... Apr 7 2014, 03:04 AM
76-914
I checked all of the schematics I can find and al... Apr 7 2014, 06:29 AM
76-914 Question #2 - Do I need to use a N/C relay off the... Apr 7 2014, 06:37 AM
76-914 Damn, :chair: I didn't consider that the ECU ... Apr 7 2014, 02:33 PM
76-914 #3 - What is the difference between a 5AG 30A fuse... Apr 28 2014, 10:28 AM
Tom Kent,
The designations before the Amperage is f... Apr 28 2014, 12:18 PM
76-914 Had to read thru some heavy stuff for my pea brain... Apr 28 2014, 06:56 PM
Dtjaden The easiest location for switched 12v on the relay... Apr 29 2014, 08:39 AM
76-914 That could be useful info for someone that is usin... Apr 29 2014, 08:59 AM
76-914 #4- I need to tie in my alt light with the suby en... May 2 2014, 08:33 PM
Dave_Darling Green/red would be the oil pressure light, not the... May 2 2014, 10:07 PM
Mike Bellis The alternator lamp work with 2 positive leads. On... May 2 2014, 11:40 PM
Tom That red/white that goes to fuse #9 on the fused s... May 3 2014, 01:32 AM
76-914 Odd. I have one sch showing GR yet today I find th... May 3 2014, 10:10 AM
Jeff Bowlsby
Odd. I have one sch showing GR yet today I find t... May 3 2014, 11:05 AM
jrrhdmust That diagram was superseded., it was not correct. ... Jun 4 2014, 03:33 PM
76-914 #5 - If you own a 914 you know the importance of a... Jun 4 2014, 01:54 PM
ClayPerrine
#5 - If you own a 914 you know the importance of ... Aug 9 2021, 01:38 PM
76-914
#5 - If you own a 914 you know the importance of... Aug 9 2021, 02:29 PM
stugray Cut & paste from my response to another forum ... Jun 4 2014, 02:04 PM
76-914 Not completely confused, yet. :D You state that t... Jun 4 2014, 02:39 PM
Dave_Darling The short answer, which is close enough for our pu... Jun 4 2014, 03:30 PM
IGTARD :shades2: :shades2: :shades2: :shades2: Jumping... Jun 4 2014, 04:34 PM
Tom Kent,
Answer for your question about wire size fo... Jun 4 2014, 05:54 PM
76-914
Kent,
Answer for your question about wire size f... Jun 5 2014, 09:07 AM
76-914 OK, another stupid electrical question. I have not... Sep 18 2014, 07:26 PM
Spoke
If I use the single pole style, which requires th... Sep 19 2014, 05:20 AM
Mike Bellis Your steel chassis should still be a better ground... Sep 18 2014, 09:30 PM
76-914 I have one chassis to tranny ground, 2 chassis to ... Sep 19 2014, 08:44 AM
76-914 #7 - I need to connect my stock '73 back up li... Nov 7 2014, 08:30 PM
Spoke Use the negative side to switch the backup lights ... Nov 7 2014, 09:35 PM
stugray For my stock trans w/ custom harness, I just took ... Nov 7 2014, 11:52 PM
76-914
Use the negative side to switch the backup lights... Nov 8 2014, 06:41 PM
76-914 Will one of our electrical wizards help me out wit... Nov 22 2014, 02:36 PM
Tom Kent,
What are you using the neutral switch for... Nov 22 2014, 03:54 PM
76-914
Kent,
What are you using the neutral switch fo... Nov 22 2014, 07:39 PM
Spoke Nice circuit.
I redrew it to better follow the fl... Nov 23 2014, 10:57 AM
76-914 Well guess what. The Suby Computer didn't like... Nov 23 2014, 08:44 PM
Spoke
Well guess what. The Suby Computer didn't lik... Nov 24 2014, 09:55 AM
Mike Bellis I have found on my Audi conversion the ECU likes t... Nov 24 2014, 08:48 AM
76-914 Spoke, no direct connections between the ECU and r... Nov 24 2014, 09:02 PM
Tom Kent,
If the gear selector is in neutral, wi... Nov 25 2014, 03:22 AM
76-914 That is exactly what I plan to do plus check it wi... Nov 25 2014, 09:11 AM
76-914 I wanted an "in use" indicator light in ... Jul 5 2015, 09:36 PM
Tom Kent,
If you have a meter, check the resista... Jul 6 2015, 03:01 AM
Spoke
Kent,
If you have a meter, check the resist... Jul 6 2015, 05:59 AM
76-914 Over my head. <_< What is "I" in... Jul 6 2015, 08:53 AM
Spoke I is current in the LED and resistor. Here's a... Jul 6 2015, 10:41 AM
76-914 A million thank you's. :worship: Jul 6 2015, 02:30 PM
76-914 Question #10 - After someone posted a question re:... Oct 19 2015, 10:56 PM
76-914 :bump: back to pg 1. Oct 21 2015, 08:26 AM
76-914 Question #11 - I want to lower my AC fan speeds ab... Jul 13 2016, 06:05 PM
Spoke
Question #11 - I want to lower my AC fan speeds a... Jul 13 2016, 11:22 PM
914forme Video on how to draw simple schematics
Question ... Jul 13 2016, 06:19 PM
76-914
Question... Jul 13 2016, 06:51 PM
stugray
EDIT: OK, I watched the video and I already knew ... Jul 13 2016, 10:34 PM
stugray The resistor would work, but for about the same am... Jul 14 2016, 07:08 AM
76-914 Stu and Jerry; thx a million. I can't wait to ... Jul 14 2016, 07:31 AM
76-914 Post #13. I'm at a Baker's Dozen so I... Jul 27 2017, 01:57 PM
76-914 Never mind. Nailed it. I ohmed out the fuse holder... Jul 27 2017, 10:08 PM
Spoke Good find. That looks like a cheap QC connector. T... Jul 27 2017, 11:39 PM
76-914
Good find. That looks like a cheap QC connector. ... Jul 28 2017, 08:31 AM
76-914 This is one of those subjects that the more I read... Nov 20 2017, 07:38 PM
Spoke
This is one of those subjects that the more I rea... Nov 22 2017, 07:59 PM
76-914 :bump: Nov 22 2017, 09:58 AM
76-914 Thanks for answering. Electrical issues remind me ... Nov 23 2017, 10:25 AM
Spoke
Thanks for answering. Electrical issues remind me... Nov 23 2017, 11:13 AM
76-914 Went back thru it and no power from the black lead... Nov 23 2017, 01:29 PM
76-914 Hey Spoke, the switch was definitely the problem. ... Nov 24 2017, 02:36 PM
76-914 Electrical Problem #15
As stated - I'm totally... Aug 8 2021, 05:28 PM
Spoke Seems confusing as the foglight switch should not ... Aug 8 2021, 06:41 PM
76-914 Jerry, With the switch pulled out - on position - ... Aug 9 2021, 01:33 PM
Spoke
Jerry, With the switch pulled out - on position -... Aug 10 2021, 11:34 AM
76-914
Jerry, With the switch pulled out - on position ... Aug 10 2021, 04:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th November 2026 - 09:17 PM |
