| Randal |
Aug 9 2004, 11:49 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I totally blew my last two runs yesterday missing shifts.
I know part of this is the driver, but I also think the Rennshift springs are suspect. When we first installed the Rennshift it took some getting used to, but it worked all the time. I've run 8 events now with the new shifter and it was fine for the first four, but not for the last four. Saturday and Sunday at Alameda I was hitting reverse, shifting from first to second. Typically this was during cornering, but that is the way course work; you just can’t sit there on the rev. limiter waiting to the corner to complete. Also during very heavy cornering (like in a slalom) shifting from second to third, it was going into fifth. On down shifts from third to second it was hitting reverse. I destroyed a great run on Saturday on the second to the last corner....just couldn't find second. (Like Grind Me A POUND!) Very ugly. So what are the ratings on the standard springs? Is there somewhere I send my existing springs to have them tested? What heaver springs are available? At Alameda I was shifting up/down 8 times. Miss any shift and you blow the run. BTW the 911 guys don't have to shift more than once. |
| JWest |
Aug 9 2004, 04:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,664 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None
QUOTE(Randal @ Aug 9 2004, 04:15 PM) Please come take a ride with me in an autox venue; you’ll find the lateral forces somewhat more powerful/heavy than what would be considered "normal." What I think does not matter. I have customers with big-track cars that like the light springs, and grocery-getter types that prefer the heavy springs. The side load at the knob is 7lbs for the standard springs and 12lbs for the heavy springs. Stock shifter is 10-11lbs with good components. Do not use the inner spring with the white spring. |
Randal Renshift Aug 9 2004, 11:49 AM
James Adams Maybe you have a bad engine or trans mount. The s... Aug 9 2004, 12:29 PM
Brad Roberts He was sold his shifter prior to us deciding that ... Aug 9 2004, 02:10 PM
James Adams It's funny - people are SO different when it c... Aug 9 2004, 02:33 PM
Randal
Randal Forgot to mention that I drove the car around Los ... Aug 9 2004, 03:24 PM
Randal
James Adams That is measured at the top of the stick where you... Aug 9 2004, 06:14 PM
Brad Roberts James.. just to let you know.. I always blame the ... Aug 9 2004, 06:28 PM
James Adams
jfort for what it's worth, i like the stiffer spring... Aug 10 2004, 09:50 AM
Eric_Shea Hi Jeff... Eric Shea, glad to meet you :lol:
(in... Aug 10 2004, 10:04 AM
jfort nice meeting you, too, eric. i learned a lot watc... Aug 10 2004, 11:35 AM
Randal Measurement:
Went out last night and purchased a ... Aug 10 2004, 11:49 AM
James Adams Thanks for verifying that measurement on your shif... Aug 10 2004, 12:03 PM
synthesisdv why don't you try some of james' nylon or ... Aug 10 2004, 12:22 PM
J P Stein Our AX this last Sunday had a curving 3rd gear bla... Aug 10 2004, 12:24 PM
Randal
Jeroen I most think it's most likely the driver and n... Aug 10 2004, 06:45 PM
Brad Roberts Randal is 6'1 200+ lbs.. we dont have much roo... Aug 10 2004, 06:50 PM
Randal
Brad Roberts I want to weld one up and machine it down so it fi... Aug 10 2004, 07:05 PM
drew365 I have one spot at Willow Springs small track that... Aug 10 2004, 08:29 PM
Randal Brad.
So this sounds like you need the car? Mar... Aug 10 2004, 08:56 PM
Randal Progress!
The new 8" steel shifter rod is bei... Aug 12 2004, 09:20 AM
maf914
James Adams ![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 12:20 AM |
