> Hub-centric 5 lug
gms
post Apr 13 2014, 08:04 AM
mount up on lathe
Stock version on left
CptTripps
post Apr 13 2014, 02:25 PM
:: Punch and Pie ::
This is timely. I think I'm fighting what this fixes...
I put my 5-lug rears on yesterday and they're just a LITTLE lose. I was thinking I needed a spacer, but taking 5mm off the back might be easier. I can have a machine shop take that off.
https://www.youtube.com/watch?v=Lw9jVBF2lOQ
jaxdream
post Apr 13 2014, 05:38 PM
QUOTE(CptTripps @ Apr 13 2014, 12:25 PM) *
If you pull those hubs you might stand a chance of destroying the wheel bearings . to tighten up put a spacer ( possibly 4-5mm ) on the backside of the stub up against the inner bearing race between the flange of the stub where the cv mounts, other wise source another set of wheel bearings just in case . YMMV.......
Jack
gms   Hub-centric 5 lug   Apr 13 2014, 08:04 AM
gms   Stock version on left Mmmm hub-centric!   Apr 13 2014, 08:05 AM
Eric_Shea   Took me a while. I was looking for the lathe mark...   Apr 13 2014, 10:47 AM
worn   Took me a while. I was looking for the lathe mar...   Apr 14 2014, 11:45 AM
Eric_Shea   Is the difference in shaft lengths the reason I h...   Apr 14 2014, 09:47 PM
SirAndy   I like that! I had a set of those 944s at som...   Apr 13 2014, 10:58 AM
Eric_Shea   Those are probably a different offset altogether...   Apr 13 2014, 11:04 AM
Travis Neff   So 5mm off the backside of the wheel bearing side?...   Apr 13 2014, 01:03 PM
CptTripps   This is timely. I think I'm fighting what this...   Apr 13 2014, 02:25 PM
jaxdream   This is timely. I think I'm fighting what thi...   Apr 13 2014, 05:38 PM
CptTripps   If you pull those hubs you might stand a chance o...   Apr 14 2014, 09:25 AM
mskala   Took me a while to realize this is about modifying...   Apr 14 2014, 09:47 AM
SirAndy   But what is the point of this? The point is to ha...   Apr 14 2014, 11:40 AM
mskala   But what is the point of this? The point is to h...   Apr 14 2014, 12:58 PM
SirAndy   However, you already have the studs there, which w...   Apr 14 2014, 01:03 PM
mskala   However, you already have the studs there, which ...   Apr 14 2014, 01:36 PM
mskala   lug nut wheel bolt   Apr 14 2014, 01:42 PM
r_towle   [quote name='SirAndy' post='2024616' date='Apr 14...   Apr 14 2014, 02:30 PM
SirAndy   So what you're saying is ... No, that's y...   Apr 14 2014, 02:32 PM
Luke M   With the later 5 lug hubs you need to put a spacer...   Apr 13 2014, 02:48 PM
Travis Neff   The worry I have with the spacer is that it pushes...   Apr 13 2014, 03:04 PM
Eric_Shea   Doug, you need the hub shaft spacer that Luke sugg...   Apr 13 2014, 05:06 PM
Mike Bellis   So what year 911 have these hubs that can be mille...   Apr 14 2014, 04:14 PM
bdstone914   911 started using the hub centric hubs in 74. Not ...   Apr 14 2014, 05:57 PM
jaxdream   Maybe the OP will enlighten us as to the source of...   Apr 14 2014, 05:47 PM
Eric_Shea   Remember, once you do this, the rotor offset will ...   Apr 14 2014, 09:56 PM
Travis Neff   Bump.. Looking to hear what rotor and caliper you...   Apr 18 2014, 11:30 PM
- Lo-Fi Version Time is now: 8th July 2025 - 05:54 PM
