gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,721 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
mount up on lathe
![]() Stock version on left Attached image(s) ![]() |
CptTripps |
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,585 Joined: 26-December 04 From: Tuscaloosa, AL and Akron, OH Member No.: 3,342 Region Association: Upper MidWest ![]() |
This is timely. I think I'm fighting what this fixes...
I put my 5-lug rears on yesterday and they're just a LITTLE lose. I was thinking I needed a spacer, but taking 5mm off the back might be easier. I can have a machine shop take that off. https://www.youtube.com/watch?v=Lw9jVBF2lOQ |
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
This is timely. I think I'm fighting what this fixes... I put my 5-lug rears on yesterday and they're just a LITTLE lose. I was thinking I needed a spacer, but taking 5mm off the back might be easier. I can have a machine shop take that off. https://www.youtube.com/watch?v=Lw9jVBF2lOQ If you pull those hubs you might stand a chance of destroying the wheel bearings . to tighten up put a spacer ( possibly 4-5mm ) on the backside of the stub up against the inner bearing race between the flange of the stub where the cv mounts, other wise source another set of wheel bearings just in case . YMMV....... Jack |
CptTripps |
If you pull those hubs you might stand a chance of destroying the wheel bearings . to tighten up put a spacer ( possibly 4-5mm ) on the backside of the stub up against the inner bearing race between the flange of the stub where the cv mounts, other wise source another set of wheel bearings just in case . YMMV....... The hubs actually come out relatively easy. (Not just "pull out" but I can get them in/out without the press.) I've already called PMS about 2 spacers and will see if I can get them here quickly. |
Lo-Fi Version | Time is now: 8th July 2025 - 05:51 PM |
