> Hub-centric 5 lug
gms
post Apr 13 2014, 08:04 AM
mount up on lathe
Stock version on left
Mike Bellis
post Apr 14 2014, 04:14 PM
Resident Electrician
So what year 911 have these hubs that can be milled down 5mm?
gms   Hub-centric 5 lug   Apr 13 2014, 08:04 AM
gms   Stock version on left Mmmm hub-centric!   Apr 13 2014, 08:05 AM
Eric_Shea   Took me a while. I was looking for the lathe mark...   Apr 13 2014, 10:47 AM
worn   Took me a while. I was looking for the lathe mar...   Apr 14 2014, 11:45 AM
Eric_Shea   Is the difference in shaft lengths the reason I h...   Apr 14 2014, 09:47 PM
SirAndy   I like that! I had a set of those 944s at som...   Apr 13 2014, 10:58 AM
Eric_Shea   Those are probably a different offset altogether...   Apr 13 2014, 11:04 AM
Travis Neff   So 5mm off the backside of the wheel bearing side?...   Apr 13 2014, 01:03 PM
CptTripps   This is timely. I think I'm fighting what this...   Apr 13 2014, 02:25 PM
jaxdream   This is timely. I think I'm fighting what thi...   Apr 13 2014, 05:38 PM
CptTripps   If you pull those hubs you might stand a chance o...   Apr 14 2014, 09:25 AM
mskala   Took me a while to realize this is about modifying...   Apr 14 2014, 09:47 AM
SirAndy   But what is the point of this? The point is to ha...   Apr 14 2014, 11:40 AM
mskala   But what is the point of this? The point is to h...   Apr 14 2014, 12:58 PM
SirAndy   However, you already have the studs there, which w...   Apr 14 2014, 01:03 PM
mskala   However, you already have the studs there, which ...   Apr 14 2014, 01:36 PM
mskala   lug nut wheel bolt   Apr 14 2014, 01:42 PM
r_towle   [quote name='SirAndy' post='2024616' date='Apr 14...   Apr 14 2014, 02:30 PM
SirAndy   So what you're saying is ... No, that's y...   Apr 14 2014, 02:32 PM
Luke M   With the later 5 lug hubs you need to put a spacer...   Apr 13 2014, 02:48 PM
Travis Neff   The worry I have with the spacer is that it pushes...   Apr 13 2014, 03:04 PM
Eric_Shea   Doug, you need the hub shaft spacer that Luke sugg...   Apr 13 2014, 05:06 PM
Mike Bellis   So what year 911 have these hubs that can be mille...   Apr 14 2014, 04:14 PM
bdstone914   911 started using the hub centric hubs in 74. Not ...   Apr 14 2014, 05:57 PM
jaxdream   Maybe the OP will enlighten us as to the source of...   Apr 14 2014, 05:47 PM
Eric_Shea   Remember, once you do this, the rotor offset will ...   Apr 14 2014, 09:56 PM
Travis Neff   Bump.. Looking to hear what rotor and caliper you...   Apr 18 2014, 11:30 PM
- Lo-Fi Version Time is now: 8th July 2025 - 06:01 PM
