T.D.C |
T.D.C |
RonnieJ |
Apr 21 2014, 05:33 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
Looking at the fan on my 1.7 at the TDC area as you are looking left to right there are two 00's a red verticle mark and then an unpainted verticle mark....which of those are TDC...Thanks
stugray |
Apr 21 2014, 06:32 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Towards the rear of the engine, pop the engine tin metal tabs up over the edge of the case and push it back.
You can see the flywheel through a notch in the trans case. Through there you will see the TDC mark on the FW. I even use that mark to set the timing. It is much easier. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:56 AM |
