My midlife crisis, (rebuilding engine, sort of) |
mobymutt |
Jan 19 2014, 12:47 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I just picked up a 1974 1.8 (carb conversion). It has been parked in an unheated garage for about 3 years, and was supposedly running fine before that, although it wont' fire up now.
My plan is to get it running, drive it on nice summer weekends, and use the other 9 months of the year to fix it up. Never worked on a car before, so looking forward to joining the fun! I'll post some pictures as soon as I figure out how... |
Steve |
Apr 25 2014, 01:39 PM
914 Guru Group: Members Posts: 5,600 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Shifting is usually the shift rod bushings. Follow the shift rod from the shifter back to the transmission and move side to side, up and down and look for slop/trashed bushings.
Brakes = Check pads, check rear brake pad clearance and most important, bleed brakes and replace the brake fluid. Regarding the speedometer, its either the speedometer angle drive on transmission, cable or speedometer in that order. Unscrew the cable off of the angle drive from the transmission. Try to turn the speedometer drive on the angle drive by hand. If it turns its broken and needs to be replaced. If it doesn't turn, put the cable back on, remove the speedometer and see if the cable end is spinning when you go for a drive. You can also do this to test the angle drive. If the cable is spinning while you drive, you will know you have a good angle drive and cable. If that looks good, you have a bad speedometer. get it rebuilt or find another one. |
Lo-Fi Version | Time is now: 28th May 2024 - 10:50 PM |
