> Electrical Question #15 Need Help Please, I'm totally stumped this time
76-914
post Apr 6 2014, 06:33 PM
I'm going to have several electrical questions. 1st, Is pin #8, on the 14 pin plug at the relay board, the only switched 12v+ source in the engine compartment? TIA, Kent
post Apr 28 2014, 10:28 AM
#3 - What is the difference between a 5AG 30A fuse vs. a AGU 30A fuse. Are they interchangeable? TIA, Kent
76-914   Electrical Question #15 Need Help Please   Apr 6 2014, 06:33 PM
Mike Bellis   I'm going to have several electrical question...   Apr 6 2014, 07:38 PM
Jeff Bowlsby   Careful, not all model years are the same. Check ...   Apr 6 2014, 09:48 PM
Tom   I checked all of the schematics I can find and all...   Apr 7 2014, 03:04 AM
76-914   I checked all of the schematics I can find and al...   Apr 7 2014, 06:29 AM
76-914   Question #2 - Do I need to use a N/C relay off the...   Apr 7 2014, 06:37 AM
Tom   Kent, Don't know why as they don't dr...   Apr 7 2014, 11:37 AM
76-914   Damn, :chair: I didn't consider that the ECU ...   Apr 7 2014, 02:33 PM
76-914   #3 - What is the difference between a 5AG 30A fuse...   Apr 28 2014, 10:28 AM
Tom   Kent, The designations before the Amperage is f...   Apr 28 2014, 12:18 PM
76-914   Had to read thru some heavy stuff for my pea brain...   Apr 28 2014, 06:56 PM
Dtjaden   The easiest location for switched 12v on the relay...   Apr 29 2014, 08:39 AM
76-914   That could be useful info for someone that is usin...   Apr 29 2014, 08:59 AM
76-914   #4- I need to tie in my alt light with the suby en...   May 2 2014, 08:33 PM
Dave_Darling   Green/red would be the oil pressure light, not the...   May 2 2014, 10:07 PM
Mike Bellis   The alternator lamp work with 2 positive leads. On...   May 2 2014, 11:40 PM
Tom   That red/white that goes to fuse #9 on the fused s...   May 3 2014, 01:32 AM
76-914   Odd. I have one sch showing GR yet today I find th...   May 3 2014, 10:10 AM
Jeff Bowlsby   Odd. I have one sch showing GR yet today I find t...   May 3 2014, 11:05 AM
jrrhdmust   That diagram was superseded., it was not correct. ...   Jun 4 2014, 03:33 PM
76-914   #5 - If you own a 914 you know the importance of a...   Jun 4 2014, 01:54 PM
ClayPerrine   #5 - If you own a 914 you know the importance of ...   Aug 9 2021, 01:38 PM
76-914   #5 - If you own a 914 you know the importance of...   Aug 9 2021, 02:29 PM
stugray   Cut & paste from my response to another forum ...   Jun 4 2014, 02:04 PM
76-914   Not completely confused, yet. :D You state that t...   Jun 4 2014, 02:39 PM
Dave_Darling   The short answer, which is close enough for our pu...   Jun 4 2014, 03:30 PM
IGTARD   :shades2: :shades2: :shades2: :shades2: Jumping...   Jun 4 2014, 04:34 PM
Tom   Kent, Answer for your question about wire size fo...   Jun 4 2014, 05:54 PM
76-914   Kent, Answer for your question about wire size f...   Jun 5 2014, 09:07 AM
76-914   OK, another stupid electrical question. I have not...   Sep 18 2014, 07:26 PM
Spoke   If I use the single pole style, which requires th...   Sep 19 2014, 05:20 AM
Mike Bellis   Your steel chassis should still be a better ground...   Sep 18 2014, 09:30 PM
76-914   I have one chassis to tranny ground, 2 chassis to ...   Sep 19 2014, 08:44 AM
76-914   #7 - I need to connect my stock '73 back up li...   Nov 7 2014, 08:30 PM
Spoke   Use the negative side to switch the backup lights ...   Nov 7 2014, 09:35 PM
stugray   For my stock trans w/ custom harness, I just took ...   Nov 7 2014, 11:52 PM
76-914   Use the negative side to switch the backup lights...   Nov 8 2014, 06:41 PM
76-914   Will one of our electrical wizards help me out wit...   Nov 22 2014, 02:36 PM
Tom   Kent, What are you using the neutral switch for...   Nov 22 2014, 03:54 PM
76-914   Kent, What are you using the neutral switch fo...   Nov 22 2014, 07:39 PM
Spoke   Nice circuit. I redrew it to better follow the fl...   Nov 23 2014, 10:57 AM
76-914   Well guess what. The Suby Computer didn't like...   Nov 23 2014, 08:44 PM
Spoke   Well guess what. The Suby Computer didn't lik...   Nov 24 2014, 09:55 AM
Mike Bellis   I have found on my Audi conversion the ECU likes t...   Nov 24 2014, 08:48 AM
76-914   Spoke, no direct connections between the ECU and r...   Nov 24 2014, 09:02 PM
Tom   Kent, If the gear selector is in neutral, wi...   Nov 25 2014, 03:22 AM
76-914   That is exactly what I plan to do plus check it wi...   Nov 25 2014, 09:11 AM
76-914   I wanted an "in use" indicator light in ...   Jul 5 2015, 09:36 PM
Tom   Kent, If you have a meter, check the resista...   Jul 6 2015, 03:01 AM
Spoke   Kent, If you have a meter, check the resist...   Jul 6 2015, 05:59 AM
76-914   Over my head. <_< What is "I" in...   Jul 6 2015, 08:53 AM
Spoke   I is current in the LED and resistor. Here's a...   Jul 6 2015, 10:41 AM
76-914   A million thank you's. :worship:   Jul 6 2015, 02:30 PM
76-914   Question #10 - After someone posted a question re:...   Oct 19 2015, 10:56 PM
76-914   :bump: back to pg 1.   Oct 21 2015, 08:26 AM
76-914   Question #11 - I want to lower my AC fan speeds ab...   Jul 13 2016, 06:05 PM
Spoke   Question #11 - I want to lower my AC fan speeds a...   Jul 13 2016, 11:22 PM
914forme   Video on how to draw simple schematics Question ...   Jul 13 2016, 06:19 PM
76-914   Video on how to draw simple schematics Question...   Jul 13 2016, 06:51 PM
stugray   EDIT: OK, I watched the video and I already knew ...   Jul 13 2016, 10:34 PM
stugray   The resistor would work, but for about the same am...   Jul 14 2016, 07:08 AM
76-914   Stu and Jerry; thx a million. I can't wait to ...   Jul 14 2016, 07:31 AM
76-914   Post #13. I'm at a Baker's Dozen so I...   Jul 27 2017, 01:57 PM
76-914   Never mind. Nailed it. I ohmed out the fuse holder...   Jul 27 2017, 10:08 PM
Spoke   Good find. That looks like a cheap QC connector. T...   Jul 27 2017, 11:39 PM
76-914   Good find. That looks like a cheap QC connector. ...   Jul 28 2017, 08:31 AM
76-914   This is one of those subjects that the more I read...   Nov 20 2017, 07:38 PM
Spoke   This is one of those subjects that the more I rea...   Nov 22 2017, 07:59 PM
76-914   :bump:   Nov 22 2017, 09:58 AM
76-914   Thanks for answering. Electrical issues remind me ...   Nov 23 2017, 10:25 AM
Spoke   Thanks for answering. Electrical issues remind me...   Nov 23 2017, 11:13 AM
76-914   Went back thru it and no power from the black lead...   Nov 23 2017, 01:29 PM
76-914   Hey Spoke, the switch was definitely the problem. ...   Nov 24 2017, 02:36 PM
76-914   Electrical Problem #15 As stated - I'm totally...   Aug 8 2021, 05:28 PM
Spoke   Seems confusing as the foglight switch should not ...   Aug 8 2021, 06:41 PM
76-914   Jerry, With the switch pulled out - on position - ...   Aug 9 2021, 01:33 PM
Spoke   Jerry, With the switch pulled out - on position -...   Aug 10 2021, 11:34 AM
76-914   Jerry, With the switch pulled out - on position ...   Aug 10 2021, 04:15 PM
- Lo-Fi Version Time is now: 18th November 2026 - 09:17 PM
