> Renshift, Springs
Randal
post Aug 9 2004, 11:49 AM
I totally blew my last two runs yesterday missing shifts.
I know part of this is the driver, but I also think the Rennshift springs are suspect.
When we first installed the Rennshift it took some getting used to, but it worked all the time. I've run 8 events now with the new shifter and it was fine for the first four, but not for the last four.
Saturday and Sunday at Alameda I was hitting reverse, shifting from first to second. Typically this was during cornering, but that is the way course work; you just can’t sit there on the rev. limiter waiting to the corner to complete.
Also during very heavy cornering (like in a slalom) shifting from second to third, it was going into fifth.
On down shifts from third to second it was hitting reverse. I destroyed a great run on Saturday on the second to the last corner....just couldn't find second. (Like Grind Me A POUND!) Very ugly.
So what are the ratings on the standard springs? Is there somewhere I send my existing springs to have them tested? What heaver springs are available?
At Alameda I was shifting up/down 8 times. Miss any shift and you blow the run.
BTW the 911 guys don't have to shift more than once.
drew365
post Aug 10 2004, 08:29 PM
These are the good old days!
I have one spot at Willow Springs small track that I have to shift under heavy side load from 2nd to 3rd and the trans either will crunch or not engage. I'm certain that it's caused by flexing on my tub. I plan on connecting my roll cage to the rear shock towers and possibly the shock towers to the top of the tranny mounts, in the near future. If that doesn't work I may fire the driver. (IMG:style_emoticons/default/smile.gif)
Randal   Renshift   Aug 9 2004, 11:49 AM
James Adams   Maybe you have a bad engine or trans mount. The s...   Aug 9 2004, 12:29 PM
Brad Roberts   He was sold his shifter prior to us deciding that ...   Aug 9 2004, 02:10 PM
James Adams   It's funny - people are SO different when it c...   Aug 9 2004, 02:33 PM
Randal
  Aug 9 2004, 03:15 PM
Randal   Forgot to mention that I drove the car around Los ...   Aug 9 2004, 03:24 PM
James Adams     Aug 9 2004, 04:12 PM
Randal
  Aug 9 2004, 05:55 PM
James Adams   That is measured at the top of the stick where you...   Aug 9 2004, 06:14 PM
Brad Roberts   James.. just to let you know.. I always blame the ...   Aug 9 2004, 06:28 PM
James Adams     Aug 10 2004, 08:38 AM
jfort   for what it's worth, i like the stiffer spring...   Aug 10 2004, 09:50 AM
Eric_Shea   Hi Jeff... Eric Shea, glad to meet you :lol: (in...   Aug 10 2004, 10:04 AM
jfort   nice meeting you, too, eric. i learned a lot watc...   Aug 10 2004, 11:35 AM
Randal   Measurement: Went out last night and purchased a ...   Aug 10 2004, 11:49 AM
James Adams   Thanks for verifying that measurement on your shif...   Aug 10 2004, 12:03 PM
synthesisdv   why don't you try some of james' nylon or ...   Aug 10 2004, 12:22 PM
J P Stein   Our AX this last Sunday had a curving 3rd gear bla...   Aug 10 2004, 12:24 PM
Randal
  Aug 10 2004, 03:20 PM
Jeroen   I most think it's most likely the driver and n...   Aug 10 2004, 06:45 PM
Brad Roberts   Randal is 6'1 200+ lbs.. we dont have much roo...   Aug 10 2004, 06:50 PM
Randal
  Aug 10 2004, 07:00 PM
Brad Roberts   I want to weld one up and machine it down so it fi...   Aug 10 2004, 07:05 PM
drew365   I have one spot at Willow Springs small track that...   Aug 10 2004, 08:29 PM
Randal   Brad. So this sounds like you need the car? Mar...   Aug 10 2004, 08:56 PM
Randal   Progress! The new 8" steel shifter rod is bei...   Aug 12 2004, 09:20 AM
maf914
  Aug 12 2004, 06:44 PM
James Adams
- Lo-Fi Version Time is now: 13th March 2026 - 12:19 AM
