pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
I am replacing my shift coupler bushings.
I purchased a white delrin set and they were way too sloppy and a poor fit. (IMG:style_emoticons/default/headbang.gif) Next up is a set of urethane and they fit much tighter but the pin still floats around in the holes which appear to be oval shaped? Not sure if I would like that play due to the pin floating in the oval shaped holes. (IMG:style_emoticons/default/blink.gif) I saw a set of solid brass bushings, these look interesting. (IMG:style_emoticons/default/shades.gif) Has any one used them? (IMG:style_emoticons/default/idea.gif) Are the pivot holes supposed to be oval shaped with slop around the pivot pin? (IMG:style_emoticons/default/idea.gif) Any brand better than others? (IMG:style_emoticons/default/idea.gif) There seems to be a lot of manufacturers out there and the prices go from $12 bucks to $40.00 for the brass ones. (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/blink.gif) Attached image(s) ![]() ![]() |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
The holes are oval per the factory design for 911s, IIRC. That allows a little fore and aft play and keeps the shift fingers from applying a load to the shift rails while in gear. I don't think 914s had that, but the free play is slight enough that it wouldn't make much difference. What 914 owners have to worry about is radial play. That's what cause shifting issues and "sloppiness". Brass/bronze bushings are gonna transmit noise/vibration.
The Cap'n |
Lo-Fi Version | Time is now: 18th September 2025 - 05:21 PM |
