Header for conversion, Pretty confusing vendors |
worn |
Apr 21 2014, 08:42 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I am installing a 3.2 porsche flat 6 air cooled in a 1972 914 body. So far so good. I would prefer heat but the offerings seem sort of dismal. Also while there appear to be two main styles of headers, I suspect it is because some vendors just pate a 911 picture in the link.
Any advice.please!? (IMG:style_emoticons/default/pray.gif) It is getting that far along. Soon I will be beating the oil tank into form. (IMG:style_emoticons/default/unsure.gif) |
GeorgeRud |
May 1 2014, 10:44 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
If you do end up gabbing some outer envelopes for the headers, please post pics as a lot of members would be interested in seeing how they're made. Only suggestion is that you not weld the outer envelope to the header as that is supposed to create a potential weak spot that can crack. There is a reason that all the factory and SSI heat exchangers are not welded.
worn |
May 1 2014, 01:52 PM
If you do end up gabbing some outer envelopes for the headers, please post pics as a lot of members would be interested in seeing how they're made. Only suggestion is that you not weld the outer envelope to the header as that is supposed to create a potential weak spot that can crack. There is a reason that all the factory and SSI heat exchangers are not welded. In my experience they put in a couple of little tacks to maintain position. I do want heat, but having the headers perform properly is more important. On the '76 2056 I am running heat exchangers I fabbed the top ends for (where they go to the flapper boxes), so I had em completely disassembled. I used Eastwood high temp paint inside and a bit of fiberglass to keep them from rattling. After the paint cooked so far so good. But I also have a CO alarm from Walmart. Route 66 purchase. Also - Thanks Marty. I am psyched. I expect grace in form. And also it is one more thing checked off. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 01:35 AM |
