> Shift coupler bushing options ?
pete000
post Apr 30 2014, 09:55 PM
I am replacing my shift coupler bushings.
I purchased a white delrin set and they were way too sloppy and a poor fit. (IMG:style_emoticons/default/headbang.gif)
Next up is a set of urethane and they fit much tighter but the pin still floats around in the holes which appear to be oval shaped? Not sure if I would like that play due to the pin floating in the oval shaped holes. (IMG:style_emoticons/default/blink.gif)
I saw a set of solid brass bushings, these look interesting. (IMG:style_emoticons/default/shades.gif)
Has any one used them? (IMG:style_emoticons/default/idea.gif)
Are the pivot holes supposed to be oval shaped with slop around the pivot pin? (IMG:style_emoticons/default/idea.gif)
Any brand better than others? (IMG:style_emoticons/default/idea.gif)
There seems to be a lot of manufacturers out there and the prices go from $12 bucks to $40.00 for the brass ones. (IMG:style_emoticons/default/shades.gif)
CMONNETT
post May 1 2014, 04:44 PM
I used the brass ones in my car. Works great, improved the shifting over the 1yr old graphite the car had in it. Haven't noticed any noise or vibration from them.
pete000   Shift coupler bushing options ?   Apr 30 2014, 09:55 PM
Cap'n Krusty   The holes are oval per the factory design for 911s...   Apr 30 2014, 10:09 PM
02loftsmoor   Do you just drive that pin out to service the bush...   Apr 30 2014, 10:13 PM
pete000   Do you just drive that pin out to service the bus...   Apr 30 2014, 10:34 PM
SLITS   The ones currently supplied are for the 911. 914 ...   Apr 30 2014, 10:36 PM
pete000   The ones currently supplied are for the 911. 914...   Apr 30 2014, 10:39 PM
Dr Evil   Ya, I dropped $20 on the graphite ones as an ...   May 1 2014, 03:54 PM
Travis Neff   jwest has the bushings with the circular pin holes...   May 1 2014, 04:27 PM
CMONNETT   I used the brass ones in my car. Works great, imp...   May 1 2014, 04:44 PM
Dr Evil   Now that I have a 914 to drive and mess with, I am...   May 1 2014, 05:12 PM
TJB/914   Now that I have a 914 to drive and mess with, I a...   May 1 2014, 06:21 PM
pete000   I spent some time on the phone this morning with P...   May 1 2014, 06:40 PM
bdstone914   I spent some time on the phone this morning with ...   May 1 2014, 09:40 PM
JWest   The ones I use are a tight fit on the pin, once as...   May 1 2014, 07:57 PM
Qarl   So what is everyone's opinion on this stock co...   May 1 2014, 08:39 PM
Racer Chris   The universal joint I use to replace the coupler a...   May 2 2014, 06:41 AM
r_towle   The universal joint I use to replace the coupler ...   May 2 2014, 06:57 AM
Racer Chris   So your solution has a new coupler and rod, with ...   May 2 2014, 07:04 AM
Qarl   So your solution has a new coupler and rod, with...   May 2 2014, 07:06 AM
Racer Chris   CHris, Can you please talk a little about the st...   May 2 2014, 07:49 AM
r_towle   So your solution has a new coupler and rod, with...   May 2 2014, 07:16 AM
Racer Chris   :( You can buy sideshift boots new and used. Th...   May 2 2014, 07:25 AM
r_towle   :( You can buy sideshift boots new and used. T...   May 2 2014, 07:29 AM
Racer Chris   no additional work except removing the tail shift...   May 2 2014, 08:20 AM
r_towle   no additional work except removing the tail shif...   May 2 2014, 09:37 AM
gonzo54   I just ordered all of my shift bushings, Bronze Re...   May 16 2020, 10:21 AM
dr914@autoatlanta.com   the originals had a perfectly round hole and no sl...   May 16 2020, 10:37 AM
gonzo54   Thanks Dr 914, I want to get going on replacing my...   May 16 2020, 01:16 PM
roblav1   Although expensive, the Apex helicoptor joint is t...   May 16 2020, 03:32 PM
gonzo54   I'm not going to have a Apex helicopter joint ...   May 16 2020, 05:15 PM
roblav1   I figured that Rick. Info was for anyone else con...   May 16 2020, 05:17 PM
DRPHIL914   i got my brass bushings for the coupler on e-bay ...   May 16 2020, 07:53 PM
gonzo54   Thanks Dr Phil for the information and ebay contac...   May 16 2020, 09:03 PM
- Lo-Fi Version Time is now: 18th September 2025 - 05:19 PM
