| vw_porsche |
Apr 28 2014, 11:44 PM
Member ![]() ![]() Group: Members Posts: 129 Joined: 2-June 13 From: Milton, Fl. Member No.: 15,954 Region Association: South East States |
So, I was taking the long way home last Tuesday night after work. After about 15 minuets I got on the interstate and got up to around 75 when all of a sudden a loud knocking started.
I thought at the time that it sounded like a nut or bold fell into the combustion chamber somehow. It sounded like a piston beating something up. After a few seconds the sound quieted down a bit. By this time I knew the damage was already done. So, I "limped" it home. I was finally able to pull the engine today and this is what I found... Now, I am not missing any nuts or bolts from my ventures, or studs from my intake. I had my air cleaners on with the rain hat covers on my 40 idf webers. And spark plugs are damaged, but complete. It looks like a stud or bold. Any ideas where this could have come from? |
| toolguy |
May 5 2014, 09:20 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
(IMG:style_emoticons/default/blink.gif) any updates what it was ??
| vw_porsche |
May 5 2014, 09:33 AM
No, I have no idea what it was. I've looked all over the carb for anything missing. And the engine looking for missing tin screws or anything else that looks out of place. I did a few tests seeing if any of the tin screws or bolts would even fit down the carb. Unless the stars were just aligned perfectly, they will not. I couldn't get anything to drop through the carb. I'm at a loss. Very very weird. |
vw_porsche Unhappy sound in engine Apr 28 2014, 11:44 PM
cwpeden Definitely looks like the remnants of a stud or se... Apr 29 2014, 12:12 AM
vw_porsche
Definitely looks like the remnants of a stud or s... Apr 29 2014, 08:25 AM
yeahmag Can you see if the piston is missing a chunk? That... Apr 29 2014, 11:45 AM
vw_porsche
Can you see if the piston is missing a chunk? Tha... Apr 29 2014, 12:17 PM
stugray Please explain how those pieces got "munched... Apr 29 2014, 12:15 PM
vw_porsche
Please explain how those pieces got "munched... Apr 29 2014, 12:20 PM
yeahmag Man... Being ferrous and in the intake like that I... Apr 29 2014, 12:21 PM
vw_porsche
Man... Being ferrous and in the intake like that ... Apr 29 2014, 12:40 PM
Cupomeat
[quote name='yeahmag' post='2030920' date='Apr 29... Apr 29 2014, 12:42 PM
yeahmag I think you need to look above that. Were you runn... Apr 29 2014, 02:36 PM
vw_porsche
I think you need to look above that. Were you run... Apr 29 2014, 03:28 PM
The Cabinetmaker Those got ingested thru the carbs. No way they wer... Apr 29 2014, 02:52 PM
yeahmag I would inspect the carbs and intake manifolds car... Apr 29 2014, 03:47 PM
r_towle Bummer....
Time for a boroscope from Home Depot..... Apr 29 2014, 06:36 PM
Elliot Cannon Shanghai Tool Supply. :D http://www.harborfr... Apr 29 2014, 06:44 PM
yeahmag I personally don't see the need for a borescop... Apr 29 2014, 06:54 PM
r_towle
I personally don't see the need for a boresco... Apr 29 2014, 07:15 PM
yeahmag What the hell was I thinking? You're right. We... Apr 30 2014, 11:16 AM
stugray How about the screws that hold the butterfly valve... Apr 29 2014, 07:15 PM
vw_porsche
How about the screws that hold the butterfly valv... Apr 29 2014, 07:20 PM
rgalla9146
How about the screws that hold the butterfly val... Apr 30 2014, 12:04 PM
cwpeden When did you put the rain hats on? Did it require ... Apr 29 2014, 11:48 PM
vw_porsche
When did you put the rain hats on? Did it require... Apr 30 2014, 10:58 AM
cwpeden I guess all we have left is sabotage.... :smash: Apr 30 2014, 12:01 PM
toolguy Comparing them to the size of the thread stitching... Apr 30 2014, 12:50 PM
vw_porsche Here is a better picture of the pieces I found in ... Apr 30 2014, 01:51 PM
yeahmag Show us the spark plug. Apr 30 2014, 02:01 PM
vw_porsche Can't get a Pic of that at the moment (at work... Apr 30 2014, 02:10 PM
Qarl That will buff right out.
OUCH... that looked pai... Apr 30 2014, 03:28 PM
ThePaintedMan What kind of air filters were you using? If foam, ... May 5 2014, 09:37 AM
vw_porsche
What kind of air filters were you using? If foam,... May 5 2014, 09:47 AM
Mblizzard Done it! Sucks but I got the t-shirt.
May 5 2014, 09:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:07 PM |
