First 914 build... V8 twin turbo SBC, 1974 v8tt conversion project |
beam944 |
Apr 15 2014, 02:44 PM
Member Group: Members Posts: 58 Joined: 15-April 14 From: Timberlake,NC Member No.: 17,254 Region Association: MidAtlantic Region |
Hi everyone...I am new to the 914 world although not new to Porsche's. I have owned 3 944's and actually loved every one of them. I came across a craigslist ad for a v8 914 and well.....here it goes.. wish me luck ...any and all input is appreciated.
This engine is just set in place as mock up only...thats actually a 1966 283 out of a ChevyII I dont know why this radiator is where its at...going to get a race aluminum in the front lots of work to do here.. will have lots of parts to sale off of this project definitely going to need some more space for 12 inch wide tires..so probably won't look like this when i'm done |
messix |
May 1 2014, 07:31 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
9k-10krpm out of a 283 is what the drag guys were getting..... I wouldn't bet on expecting one to last long for any repeated and extended time.
I'm on board with the small displacement and stroke engine for a v8 conversion, I've been working on getting parts and pieces to do a ls1 block with 4.8 crank. I have a pretty good chunk of my paycheck going to my ex for child support so using stock parts and finding deals is just the waiting game. the ls1 blocks are over valued so I might end up going with a 5.3 alloy block. those are hard to find but much less $$. the allure of a all aluminum ls motor that could make 400-500 hp N/A pretty easily is just too hard to resist. |
andys |
May 4 2014, 09:07 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
9k-10krpm out of a 283 is what the drag guys were getting..... I wouldn't bet on expecting one to last long for any repeated and extended time. I'm on board with the small displacement and stroke engine for a v8 conversion, I've been working on getting parts and pieces to do a ls1 block with 4.8 crank. I have a pretty good chunk of my paycheck going to my ex for child support so using stock parts and finding deals is just the waiting game. the ls1 blocks are over valued so I might end up going with a 5.3 alloy block. those are hard to find but much less $$. the allure of a all aluminum ls motor that could make 400-500 hp N/A pretty easily is just too hard to resist. I had a similar plan until a complete low mileage LS1 came across my path (Z28 pull-out). LS1 with a 4.8L crank/rods works out to 312 cu. in, if memory serves me correctly. I do recall the Renegade Hybrids built such a motor. With all that RPM you are considering, the money will be spent on the valve train. If you're in a pinch for $$, perhaps you should consider a stock 4.8L LSx. Plenty of them in the truck salvage yards for cheap, and the weight penalty is only 63lbs vs. the alloy block. Andys |
beam944 |
May 5 2014, 03:06 PM
9k-10krpm out of a 283 is what the drag guys were getting..... I wouldn't bet on expecting one to last long for any repeated and extended time. I'm on board with the small displacement and stroke engine for a v8 conversion, I've been working on getting parts and pieces to do a ls1 block with 4.8 crank. I have a pretty good chunk of my paycheck going to my ex for child support so using stock parts and finding deals is just the waiting game. the ls1 blocks are over valued so I might end up going with a 5.3 alloy block. those are hard to find but much less $$. the allure of a all aluminum ls motor that could make 400-500 hp N/A pretty easily is just too hard to resist. I had a similar plan until a complete low mileage LS1 came across my path (Z28 pull-out). LS1 with a 4.8L crank/rods works out to 312 cu. in, if memory serves me correctly. I do recall the Renegade Hybrids built such a motor. With all that RPM you are considering, the money will be spent on the valve train. If you're in a pinch for $$, perhaps you should consider a stock 4.8L LSx. Plenty of them in the truck salvage yards for cheap, and the weight penalty is only 63lbs vs. the alloy block. Andys The wife has ok'd me to build!! I have to start before she changes her mind...lol |
Lo-Fi Version | Time is now: 28th May 2024 - 10:50 PM |
