Hot start |
Hot start |
Pursang |
May 4 2014, 07:33 PM
Member Group: Members Posts: 233 Joined: 19-January 13 From: Beaverton Member No.: 15,386 Region Association: Pacific Northwest |
I've heard about this problem before. You've been driving on a warm day and, at some inconvenient stop, the starter won't engage. Dead. Nothing. Nada. Battery is fine but no action from the solenoid. Bump start works and you get back to your home just fine. Next day the car starts as if nothing was wrong. People with more knowledge than I, and they are legion, tell me that this is a common problem with the teener. Thanks for that but I would like to know what the root cause problem is. My car has been run on hotter days for longer periods and this is the first time I've experienced this failure. Is it a wiring problem, a weak fuse, a tired old original part or what? Inquiring minds want to know. Thanks.
(74 2L) |
malcolm2 |
May 5 2014, 08:47 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I have similar, but not exactly the same..... This is not really in a HOT situation, but I have noticed it since the very first day I tried to start the car.
I turn the key and sometimes I get nothing... I think I have not turned it far enough and put alittle more turn on it and nothing. Turn the key off, then FULL to the right and she fires right up. Has never left me stranded. I was thinking about replacing (what I'll call) the ignition switch. It is the white piece in the steering column that mates with the bottom of the key and the wires connect to the bottom of it. Without the key switch in the car it just takes a screw driver to turn it and start the car. So which is it for me? Ignition or Hot start relay? Hell for $25 I should do the hot start thingy. Clark |
Lo-Fi Version | Time is now: 6th June 2024 - 04:59 AM |
