> 911 issues
ripper911
post May 11 2014, 07:15 PM
corde pulsum tangite
OK, my 911 is cranking about once a day.
Yesterday it cranked with my brother messing with the wire that runs from the coil to the distributor. Today I made sure it had a good connection before trying it, and it cranked and idled well. I moved everything out of the way to test drive it and it wouldn't crank. It may have flooded, there was a strong gas smell. After trying to crank bit for a minute it started sounding bad, it was popping or knocking maybe backfiring while trying to crank, but after that it would only squeal when engaging the starter so I stopped.
There's something going on...
scotty b
post May 11 2014, 08:01 PM
rust free you say ?
Need to be more specific. Cranking and firing are two different things. The engine will crank over all day long and not fire depending on some variables. It will not crank at all depending on other variables. It will fire and run ocassionaly due to other varialbes.
BUT first, is this 3.0 carb'ed or injected ? Anything special with the ignition or is it all stock ? What CDI box is in it ?
- Lo-Fi Version Time is now: 14th August 2025 - 07:13 PM
