Running Really Hot on the Track, I don't necessarily mean fast |
ww914 |
May 10 2014, 03:51 PM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Yesterday at Buttonwillow for our DE, the temperature was not all that hot, but I could only get in 2 laps at race speed before my CHT gauge started hollering at me. Here are the maximum values from yesterday:
Cyl #1 384 degrees Cyl #2 357 degrees Cyl #3 433 degrees Cyl #4 402 degrees I have the alarm set at 400 degrees, so each time it reached that temp, I backed off and let it cool down and finished each session with just a Sunday drive. Here's what I have: My engine is a 2270 built by Original Customs 2 40 DLRAs: 150 main jets 180 air correction jets 34 venturis 9164.2 emulsion tubes 75 idle jets 50 pump jets Both carbs are accurately sync'd and the a/f gauge shows between 13 - 14 all through the progression to WOT The timing is set to about 30 degrees I am running a stock cooling system with the thermostat and flaps working properly. I pulled engine tin to look for obstructions. None. I am running a Sebtrab 8 x 10 oil cooler but my temps are over 220 when pushing it hard. No fans. I am not sure where to go from here: alternate cooling, larger oil cooler, fans? Any suggestions would be appreciated. |
Randal |
May 10 2014, 06:34 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Where is your external oil cooler? And how is the air currently extracted? |
ww914 |
May 10 2014, 07:18 PM
Randal |
May 11 2014, 09:51 PM
Where is your external oil cooler? And how is the air currently extracted? It is on the passenger side rear, as low as a dare to go. There is quite a bit of space behind it. I can't tell if the cooler is just hanging there or do you have a front shroud to direct funnel the air through the cooler? Plenty of space in back, but without capturing the air and forcing it through the cooler you are likely losing a bunch of cfm's that would help to cool the oil. Can you run a (big) tube from the front of the car to to the engine firewall in front of the fan? All the old guys used to do that and it works. I think Foley's car has one of those tubes. He could tell you how much it helped. |
ww914 |
May 12 2014, 08:46 AM
QUOTE I can't tell if the cooler is just hanging there or do you have a front shroud to direct funnel the air through the cooler? Plenty of space in back, but without capturing the air and forcing it through the cooler you are likely losing a bunch of cfm's that would help to cool the oil. Can you run a (big) tube from the front of the car to to the engine firewall in front of the fan? All the old guys used to do that and it works. I think Foley's car has one of those tubes. He could tell you how much it helped. I did some further checking of a/f and cyl temps yesterday. With the original setup I ran the car pretty hard on a remote stretch of road to try to simulate the track. The first run showed this: 13.5 at redline #1 336 #2 291 #3 368 #4 339 This was with 150 mains and 180 a/c jets After changing the 180s to 170s, I got a better a/f reading, but temps were higher. Maybe because everything was just hotter by then. Second run showed: 12.6 at redline #1 343 #2 311 #3 384 #4 357 At cruise on the way home, after resetting the CHT, I got the following max CHT readings at 60 mph in 4th gear: #1 332 #2 300 #3 381 #4 341 Today, I am going to move my oil catch can and move my oil cooler down a couple of inches and rework the air scoop. My oil temps were running just a bit over 220 and my oil pressure was good. Tomorrow I will pick up some larger jets to play with and see what happens. As I think about other fixes, I have come up with these ideas: Installing Foley's remote oil cooler set up that eliminates the stock cooler and adds a deflector to get more air to 3 & 4. Adding a GT all screen deck lid. Installing a FAT fan setup with a 911 blower. Installing NACA air ducts on the side of the car to get more air to the blower. Comments welcomed. |
Lo-Fi Version | Time is now: 11th June 2024 - 07:13 AM |
