| rgolia |
May 12 2014, 01:56 PM
GeoJoe ![]() ![]() ![]() Group: Members Posts: 721 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States
(IMG:style_emoticons/default/WTF.gif) I complete the rebuild on the rear suspension and now the starter does not work. It does not make a sound...dead. I even installed the replacement starter I had laying around (high torque unit from pelican), and it does not work. What did I screw up this time? (IMG:style_emoticons/default/hissyfit.gif)
| stugray |
May 12 2014, 02:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE That's a bad idea. You always want to either remove the ground or both, but never just the positive. Why is that? That is the first Ive heard that. I always only remove the Positive side unless I am removing the whole battery. It should not hurt anything. |
rgolia Starter issues May 12 2014, 01:56 PM
SirAndy Did you forget to reattach the ground strap on the... May 12 2014, 01:58 PM
rgolia nope that is still attached. I did not remove the... May 12 2014, 02:06 PM
SirAndy I only disconnected the positive side of the batt... May 12 2014, 02:10 PM
rgolia I am full of bad ideas....the first one is thinkin... May 12 2014, 02:14 PM
Tom RG,
Have someone else turn the key and measure... May 12 2014, 02:16 PM
rgolia I did put in one of your fuse kits and I will do t... May 12 2014, 02:27 PM
I ... May 12 2014, 03:12 PM
Cap'n Krusty
... May 12 2014, 06:30 PM
toolguy If you are by yourself, remove the yellow lead at ... May 12 2014, 03:15 PM
Tom Andy is so right, but there is more! Batteries... May 12 2014, 04:52 PM
Java2570
Andy is so right, but there is more! Batterie... May 12 2014, 05:19 PM
stugray I understood the safety aspect.
I just thought peo... May 12 2014, 05:27 PM
stugray
I understand that.
I thought that it was being ... May 12 2014, 06:34 PM
rgolia great info on disconnecting the battery..so neg fi... May 13 2014, 08:34 AM
McMark Did you reconnect the yellow wire to the TOP of th... May 13 2014, 08:46 AM
Kansas 914
Did you reconnect the yellow wire to the TOP of t... May 13 2014, 08:54 AM
rgolia nope that is not it. Yellow wire connected to the... May 14 2014, 07:52 AM
stugray If you short the big black wire (from the battery)... May 14 2014, 08:03 AM
76-914
If you short the big black wire (from the battery... May 14 2014, 08:19 AM
rgolia so I connect one lead to the yellow wire and one t... May 14 2014, 10:37 AM
r_towle
so I connect one lead to the yellow wire and one ... May 14 2014, 10:45 AM
stugray
In the pic, the big black wire and the big red w... May 14 2014, 12:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th October 2026 - 09:22 AM |
