| Mblizzard |
May 12 2014, 04:01 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Ok 73 2.0 built to a 2056. Currently running points. Checked dwell and set to specs. I was setting the timing and I have a timing light that you can set in the advance.
1st question: Can you use the advance setting on the timing light instead of the 27 at 3500 rpm? 2nd question: My dizzy has 2 vacuum ports. One is advance and one is retard. My throttel body only has one vacumm port for the dizzy. Do I need both hooked up? 3rd Question: Do I have the vacuum line on the correct (advance) side? 4th Question: when I check the timing (just for fun) with the vacuum hose hooked up as shown the timing is not anywhere close to 27 at any rpm. That seems odd. |
Java2570 1) yes
2) if you only have the one throttle body p... May 12 2014, 04:17 PM
stugray
yes.
Push the rear tin back over the engine cas... May 12 2014, 04:20 PM
The Cabinetmaker Remove the vacuum line and plug it when timing May 12 2014, 05:17 PM
914_teener Yea...I was gonna say that....also, but I'm no... May 12 2014, 05:22 PM
Mblizzard I think I will try the advance light method as I h... May 12 2014, 07:31 PM
r_towle Looks to me like you have the vacuum line hooked u... May 12 2014, 09:13 PM
Bleyseng That is the vacuum retard that the hose is hooked ... May 13 2014, 05:11 AM
Mblizzard So we have a couple of differing opinions on the c... May 13 2014, 05:58 AM
r_towle
So we have a couple of differing opinions on the ... May 13 2014, 07:23 AM
Mblizzard
So we have a couple of differing opinions on the... May 13 2014, 07:39 AM
type47
Anyone have a definitive answer as to which side ... May 13 2014, 07:29 AM
Java2570 Bleyseng is correct and every hose diagram I'v... May 13 2014, 06:58 AM
r_towle Oh, put a hose on each port, one at a time and suc... May 13 2014, 07:25 AM
r_towle Remove the hose and cap it so you don't have a... May 13 2014, 07:44 AM
Java2570 http://www.914world.com/bbs2/index.php?showtopic=1... May 13 2014, 07:45 AM
Mblizzard Ok so I removed the hose from the regard side and ... May 13 2014, 08:45 AM
Cap'n Krusty Time for me to check in. The diameter of the reta... May 13 2014, 09:16 AM
r_towle
Time for me to check in. The diameter of the ret... May 13 2014, 06:42 PM
Cap'n Krusty
Time for me to check in. The diameter of the re... May 13 2014, 07:44 PM
barefoot OK, i have a ditzzy with both vacuum ports and am ... May 13 2014, 11:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 27th September 2026 - 05:59 PM |
