| mobymutt |
May 12 2014, 04:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I am attempting to diagnose my non-working wipers by testing the switch directly.
So far I have removed the steering wheel and removed the 4 screws inside. The stuff in the column is 'loose' now, but I can't actually remove anything, only pull it out by about 1/2" or so. Is there a trick? I am afraid of breaking something if I pull too hard. |
| mobymutt |
May 13 2014, 07:16 AM
So I have the wiper switch out now. It does seem to have three positions, although they are not smooth at all, and I can't always get it into all three positions without a lot of messing around.
For testing, which wires should be connected in the three positions? I see a black, green, black/white, and black yellow. |
mobymutt wiper switch help needed May 12 2014, 04:14 PM
rosenfe [quote name='mobymutt' date='May 12 20... May 12 2014, 04:27 PM
The Cabinetmaker Remove the knee pad and unplug the two white plast... May 12 2014, 04:30 PM
green914
I am attempting to diagnose my non-working wipers... May 12 2014, 04:32 PM
mobymutt Unplug the wires, thanks, I'll give it a go... May 12 2014, 05:00 PM
mobymutt Well, I guess I should have had a closer look arou... May 12 2014, 05:39 PM
Bob L. The washer spray isn't powered by a pump. Ther... May 12 2014, 06:12 PM
mobymutt
The washer spray isn't powered by a pump. The... May 12 2014, 06:18 PM
Bob L.
The washer spray isn't powered by a pump. Th... May 12 2014, 06:23 PM
mobymutt Anybody? I can't seem to get continuity acros... May 13 2014, 05:25 PM
bdstone914 Do you have a wiring diagram? You will need one to... May 13 2014, 10:18 PM
mobymutt I have the wiring 'flow' diagram from the ... May 14 2014, 06:35 AM
eitnurg
I have the wiring 'flow' diagram from the... May 14 2014, 07:04 AM
mobymutt Ok, at some point I will need a new wiper switch. ... May 17 2014, 05:50 PM
Bartlett 914
Ok, at some point I will need a new wiper switch.... May 18 2014, 06:54 AM
ripper911 I used the testing procedure in tech tips 700 to d... May 18 2014, 07:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2026 - 10:19 AM |
