> Headlights pop fuse at battery
dadaDaveed
post May 13 2014, 09:06 PM
I finally put a battery in my 914 LS1 conversion today. Nothing blew up, nothing caught fire... a good start I think. I have the JWest fuse panel and as a precaution, I also installed a small fuse block at the battery.
Here's my dilemma. I can turn on the parking lights, but turning on the headlights immediately pops a fuse at the battery (I've gone as high as a 30 amp fuse). None of the fuses in the JWest panel have blown.
I checked the fuse panel, headlight switch, and headlight relay. All seem to be wired correctly with no visible shorts.
I currently have H4 headlights installed… for the time being the wiring is stock. A friend suggested the H4's are drawing too much current, so I tried again with the bulbs unplugged… same result.
I'm stumped. Where do I look next?
Mike Bellis
post May 13 2014, 09:24 PM
Resident Electrician
Most likely the terminal on the fuse panel is shorted to ground. Unbolt the fuse panel under the dash, let it hang and try again.
dadaDaveed
post May 13 2014, 09:36 PM
QUOTE(Mike Bellis @ May 13 2014, 10:24 PM) *
I thought that too... the fuse panel is the first place I went. It's been hanging the whole time and I get the same result.
- Lo-Fi Version Time is now: 12th March 2026 - 07:49 AM
