| dadaDaveed |
May 13 2014, 09:06 PM
Member ![]() ![]() Group: Members Posts: 111 Joined: 19-February 09 From: San Antonio, TX Member No.: 10,071 Region Association: Southwest Region |
I finally put a battery in my 914 LS1 conversion today. Nothing blew up, nothing caught fire... a good start I think. I have the JWest fuse panel and as a precaution, I also installed a small fuse block at the battery.
Here's my dilemma. I can turn on the parking lights, but turning on the headlights immediately pops a fuse at the battery (I've gone as high as a 30 amp fuse). None of the fuses in the JWest panel have blown. I checked the fuse panel, headlight switch, and headlight relay. All seem to be wired correctly with no visible shorts. I currently have H4 headlights installed… for the time being the wiring is stock. A friend suggested the H4's are drawing too much current, so I tried again with the bulbs unplugged… same result. I'm stumped. Where do I look next? |
| Tom |
May 14 2014, 02:32 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
I hope you have a good print to follow. I will post a pic of what I have.
You have a short after the headlight switch. The power comes thru the key switch to terminal 15 of the headlight switch (E1). First notch of the headlight switch does not energize the headlights, second notch does. Second notch feeds power to the headlight relay (J) and the fog light relay (J7). It sounds like your issue it is before the fuses on the cabin fuse panel. Your fuse at the battery is popping because that part of the electrical circuit was previously unfused. If this condition had happened prior to your fuse installation at the battery, you would have let out the magic smoke. Tom Attached thumbnail(s) |
dadaDaveed Headlights pop fuse at battery May 13 2014, 09:06 PM
Cap'n Krusty The light switch seems like the logical place to s... May 13 2014, 09:13 PM
dadaDaveed
The light switch seems like the logical place to ... May 13 2014, 09:33 PM
Mike Bellis Most likely the terminal on the fuse panel is shor... May 13 2014, 09:24 PM
dadaDaveed
Most likely the terminal on the fuse panel is sho... May 13 2014, 09:36 PM
dadaDaveed Ok, I solved the problem… sorta. After trying a... May 14 2014, 06:04 AM
Tom dadaDaveed,
Since you have a conversion, it is... May 14 2014, 02:07 PM
dadaDaveed Yes, the battery side fuse panel has done a great ... May 15 2014, 11:16 PM
dadaDaveed Update: The old headlight relay had 4 terminals a... May 15 2014, 11:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 07:46 AM |
