Coolant leak question Renegade conversion |
HalfMoon |
May 13 2014, 07:29 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
So, I've discovered a little coolant leak in my older Renegade SB conversion.
It's coming from the upper driverside engine coolant outlet (pictured). Quite difficult to access. Hard to know if it's the hose clamp (adjustment tightening un-accessable until and unless some things are gotten out of the way) or the black housing that the hose attaches to, or the aluminum housing that bolts to the block. Probably the only way to know what the heck is going on is to access and remove. Here's the question. Of you Renegade conversion owners or those who have direct experience working on one, is it better to remove the drivers side valve cover to access this housing or come from below removing the auxiliary water pump to access the area? Sidebar question. Is the black spigot that the hose is attached to supposed to "swivel" a bit or is it in fact LOOSE? I see that some of the other spigots (elsewhere) do swivel slightly and some don't (none of them that swivel or not are leaking). So....I wonder if I'll access from on high or from below. |
Cap'n Krusty |
May 14 2014, 08:44 AM
Having been a tech/shop owner for 40 years gives me a little experience with plastic coolant fittings on German cars. I think it's NUTS! I've changed literally hundreds of failed plastic cooling system parts. They get brittle and fracture, hot coolant erodes them, looking at them funny causes leaks. Some aftermarket cooling system parts are made of aluminum because the market is there for a better product!
The Cap'n |
Nine_14 |
May 14 2014, 08:49 AM
Member Group: Members Posts: 311 Joined: 30-August 12 From: Germany Member No.: 14,873 Region Association: Germany |
Having been a tech/shop owner for 40 years gives me a little experience with plastic coolant fittings on German cars. I think it's NUTS! I've changed literally hundreds of failed plastic cooling system parts. They get brittle and fracture, hot coolant erodes them, looking at them funny causes leaks. Some aftermarket cooling system parts are made of aluminum because the market is there for a better product! The Cap'n (IMG:style_emoticons/default/agree.gif) For manufactures plastic is the cheapest way, for mechanics it is a predetermined breaking point. |
Lo-Fi Version | Time is now: 11th June 2024 - 12:45 PM |
