Coolant leak question Renegade conversion |
HalfMoon |
May 13 2014, 07:29 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
So, I've discovered a little coolant leak in my older Renegade SB conversion.
It's coming from the upper driverside engine coolant outlet (pictured). Quite difficult to access. Hard to know if it's the hose clamp (adjustment tightening un-accessable until and unless some things are gotten out of the way) or the black housing that the hose attaches to, or the aluminum housing that bolts to the block. Probably the only way to know what the heck is going on is to access and remove. Here's the question. Of you Renegade conversion owners or those who have direct experience working on one, is it better to remove the drivers side valve cover to access this housing or come from below removing the auxiliary water pump to access the area? Sidebar question. Is the black spigot that the hose is attached to supposed to "swivel" a bit or is it in fact LOOSE? I see that some of the other spigots (elsewhere) do swivel slightly and some don't (none of them that swivel or not are leaking). So....I wonder if I'll access from on high or from below. |
MMW |
May 14 2014, 09:50 AM
Member Group: Members Posts: 152 Joined: 6-October 13 From: Northern NJ Member No.: 16,477 Region Association: North East States |
If you have to remove this I would at the least replace the plastic elbow just because you are in there anyway. As stated already lots of heating/cooling cycles equals a brittle part. Better to find a replacement in brass, my opinion.
HalfMoon |
May 14 2014, 09:55 AM
If you have to remove this I would at the least replace the plastic elbow just because you are in there anyway. As stated already lots of heating/cooling cycles equals a brittle part. Better to find a replacement in brass, my opinion. Yes! I'm trying to source that now. I was thinking the same thing. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:31 PM |
