> Paint job
partwerks
post May 11 2014, 04:46 PM
My car is on it's second color already, and I would like to change it from the previous owner.
I'm wondering how the body shop goes about painting over existing colors to get it to stick??
partwerks
post May 11 2014, 09:29 PM
Are you saying the baking soda would remove just the last layer?
Can't say at this point, but haven't heard of baking soda blasting, much less anyone in this area who would have it, but I don't know that for a fact. Sandblasting would be more readily available. Would be nice to keep the mechanical, and body side of things in close proximity to one another if I were to do it.
Would be nice to try and do everything except the cab. The only rust spot I have on it is on the passenger sail panel the size of a .50 cent piece.
saigon71
post May 14 2014, 08:47 PM
QUOTE(partwerks @ May 11 2014, 11:29 PM) *
Man, if you're sure you only have a .50 cent piece of rust on the sail panel, blasting of any type may be overkill, but that depends on what the purpose of the car will be. I'm not sure it is necessary for a regular driver.
Same goes for the paint itself...certainly stripping it to bare metal is the best approach. But I ended up hiring a guy to spray over the factory paint and a respray. I spent some time filling and sanding imperfections out of the last layer of paint, but it turned out very nice for a 9 month daily driver.
Supplies, primer, paint and paying the guy to spray it cost me about $800.
Evil914
post May 15 2014, 09:11 PM
QUOTE(saigon71 @ May 14 2014, 07:47 PM) *
I bought a small blaster that looks and works kinda like a gravity feed paint gun.Gets those crusty spots clean fast.Less than $30.Works great just make sure you don't blow any moisture out of your airlines.wet sand won't come out.
partwerks   Paint job   May 11 2014, 04:46 PM
ConeDodger   Primer. The paint has to be compatible or it will ...   May 11 2014, 05:18 PM
partwerks   Primer. The paint has to be compatible or it will...   May 11 2014, 05:27 PM
scotty b   quick, cheap and easy ( MAACO ) they would scuff ...   May 11 2014, 05:32 PM
green914   You can always tear it down, and have the old pain...   May 11 2014, 05:35 PM
bembry   You can always tear it down, and have the old pai...   May 12 2014, 07:21 AM
green914   :) this one needs the glass removed, and it will b...   May 11 2014, 05:38 PM
partwerks   Is everything in the interior all removed as well?   May 11 2014, 06:35 PM
green914   Is everything in the interior all removed as well...   May 11 2014, 07:09 PM
partwerks   Maybe it's not as bad as I think on removal of...   May 11 2014, 07:50 PM
rdomeck   If you don't want to take it that far down you...   May 11 2014, 08:51 PM
partwerks   Are you saying the baking soda would remove just t...   May 11 2014, 09:29 PM
worn   Are you saying the baking soda would remove just ...   May 11 2014, 09:59 PM
dan_the _body_guy   Are you saying the baking soda would remove just...   May 11 2014, 10:29 PM
saigon71   Are you saying the baking soda would remove just ...   May 14 2014, 08:47 PM
Evil914   Are you saying the baking soda would remove just...   May 15 2014, 09:11 PM
914350   Personaly I would never paint over an old existing...   May 12 2014, 12:29 PM
rick 918-S   I would only repaint over the original finish. Fac...   May 12 2014, 03:52 PM
Highland   Has anyone used oven cleaner to strip a respray? ...   May 12 2014, 04:20 PM
scotty b   Has anyone used oven cleaner to strip a respray? ...   May 12 2014, 08:12 PM
partwerks   Has anyone used oven cleaner to strip a respray? ...   May 12 2014, 09:21 PM
green914   You can always tear it down, and have the old pa...   May 12 2014, 04:20 PM
bembry   [quote name='bembry' post='2036411' date='May 12 ...   May 13 2014, 06:36 PM
JRust   Just do the plastic dip & see what you like. L...   May 13 2014, 07:03 PM
rdomeck   I run a fabrication business and I take in restora...   May 13 2014, 08:16 PM
dan_the _body_guy   im in the process of doing a "simple repaint...   May 14 2014, 09:27 PM
partwerks   Just want to change the color is all I am after, b...   May 14 2014, 09:46 PM
dan_the _body_guy   Just want to change the color is all I am after, ...   May 14 2014, 10:16 PM
- Lo-Fi Version Time is now: 19th July 2025 - 04:12 AM
