> killing the lawnmower
ripper911
post May 17 2014, 07:45 PM
corde pulsum tangite
What are the chances that I could just tighten the nuts which hold the heat exchangers on without pulling the studs out?
I'm about to set the car up for a morning valve adjustment and figured I'd spray the exhaust nuts with pb blaster and let it soak overnight in hopes of tightening them up.
r_towle
post May 17 2014, 07:50 PM
Custom Member
QUOTE(ripper911 @ May 17 2014, 09:45 PM) *
When I have had the HE,s leak at the head, the only way it got them to stop was to remove the muffler, but leave on bolt holding the weight at the rear bracket.
Then I tighten up the heat exchangers...
After tight, I install the muffler again.
Rich
ripper911   killing the lawnmower   May 17 2014, 07:45 PM
r_towle   What are the chances that I could just tighten th...   May 17 2014, 07:50 PM
kmwvmarip   I too recently took off the Heat exchangers and I ...   May 17 2014, 08:54 PM
ClayPerrine   Replace the copper gaskets that go between the hea...   May 17 2014, 10:13 PM
malcolm2   Replace the copper gaskets that go between the he...   May 19 2014, 07:04 AM
messix   use a 1/4 " drive ratchet. harder to fuck it...   May 18 2014, 02:41 AM
Allan   use a 1/4 " drive ratchet. harder to fuck i...   May 18 2014, 05:46 AM
ripper911   :angry: I know what by it's so loud now... ...   May 18 2014, 02:30 PM
r_towle   :angry: I know what by it's so loud now......   May 18 2014, 02:49 PM
Larmo63   My car is backfiring on deceleration, not to hijac...   May 18 2014, 02:37 PM
ripper911   It is jacked up... I don't have any nuts for ...   May 18 2014, 02:55 PM
r_towle   Just get normal nuts, they work fine   May 18 2014, 03:08 PM
ripper911   Done and DONE! Sounds much better!   May 18 2014, 05:44 PM
ClayPerrine   There is a Mercedes nut used on their exhaust mani...   May 18 2014, 09:43 PM
stugray   You can get a 8mm thread nut that takes a 12mm wre...   May 18 2014, 10:42 PM
malcolm2   You can get a 8mm thread nut that takes a 12mm wr...   May 19 2014, 07:07 AM
Larmo63   Are these copper washers available?   May 19 2014, 07:07 AM
stugray   I think there is some confusion above. The coppe...   May 19 2014, 07:26 AM
- Lo-Fi Version Time is now: 16th April 2026 - 04:40 PM
