| ripper911 |
May 17 2014, 07:45 PM
corde pulsum tangite ![]() ![]() ![]() ![]() Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
What are the chances that I could just tighten the nuts which hold the heat exchangers on without pulling the studs out?
I'm about to set the car up for a morning valve adjustment and figured I'd spray the exhaust nuts with pb blaster and let it soak overnight in hopes of tightening them up. |
| kmwvmarip |
May 17 2014, 08:54 PM
Karl M. ![]() ![]() Group: Members Posts: 74 Joined: 9-April 12 From: Mariposa, California Member No.: 14,354 Region Association: Central California |
I too recently took off the Heat exchangers and I had a stud come out. I suppose I would just double up on the nut and screw it back in again, right? Anything else to do while I am there?
Noob question prolly, but thanks in advance. |
ripper911 killing the lawnmower May 17 2014, 07:45 PM
r_towle
What are the chances that I could just tighten th... May 17 2014, 07:50 PM
ClayPerrine Replace the copper gaskets that go between the hea... May 17 2014, 10:13 PM
malcolm2
Replace the copper gaskets that go between the he... May 19 2014, 07:04 AM
messix use a 1/4 " drive ratchet.
harder to fuck it... May 18 2014, 02:41 AM
Allan
harder to fuck i... May 18 2014, 05:46 AM
ripper911 :angry: I know what by it's so loud now...
... May 18 2014, 02:30 PM
r_towle
:angry: I know what by it's so loud now...... May 18 2014, 02:49 PM
Larmo63 My car is backfiring on deceleration, not to hijac... May 18 2014, 02:37 PM
ripper911 It is jacked up... I don't have any nuts for ... May 18 2014, 02:55 PM
r_towle Just get normal nuts, they work fine May 18 2014, 03:08 PM
ripper911 Done and DONE! Sounds much better! May 18 2014, 05:44 PM
ClayPerrine There is a Mercedes nut used on their exhaust mani... May 18 2014, 09:43 PM
stugray You can get a 8mm thread nut that takes a 12mm wre... May 18 2014, 10:42 PM
malcolm2
You can get a 8mm thread nut that takes a 12mm wr... May 19 2014, 07:07 AM
Larmo63 Are these copper washers available? May 19 2014, 07:07 AM
stugray
I think there is some confusion above.
The coppe... May 19 2014, 07:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 02:55 PM |
