| mobymutt |
May 12 2014, 04:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I am attempting to diagnose my non-working wipers by testing the switch directly.
So far I have removed the steering wheel and removed the 4 screws inside. The stuff in the column is 'loose' now, but I can't actually remove anything, only pull it out by about 1/2" or so. Is there a trick? I am afraid of breaking something if I pull too hard. |
| mobymutt |
May 17 2014, 05:50 PM
Ok, at some point I will need a new wiper switch. In the meantime, I would just like to wire in the wiper to the existing toggle switch that the previous owner mounted on the fusebox.
Do the wiper wires run near the fusebox (I couldn't see them there when I looked today)? Or do I need to cut them at the connector in the steering column, and then feed new wires back to toggle switch? |
| Bartlett 914 |
May 18 2014, 06:54 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,219 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Ok, at some point I will need a new wiper switch. In the meantime, I would just like to wire in the wiper to the existing toggle switch that the previous owner mounted on the fusebox. Do the wiper wires run near the fusebox (I couldn't see them there when I looked today)? Or do I need to cut them at the connector in the steering column, and then feed new wires back to toggle switch? Don't screw around trying to wire in something. You make a wiring mistake and it could be expensive. Don't drive the car in the rain until a new switch comes in. Price should be reasonable. |
mobymutt wiper switch help needed May 12 2014, 04:14 PM
rosenfe [quote name='mobymutt' date='May 12 20... May 12 2014, 04:27 PM
The Cabinetmaker Remove the knee pad and unplug the two white plast... May 12 2014, 04:30 PM
green914
I am attempting to diagnose my non-working wipers... May 12 2014, 04:32 PM
mobymutt Unplug the wires, thanks, I'll give it a go... May 12 2014, 05:00 PM
mobymutt Well, I guess I should have had a closer look arou... May 12 2014, 05:39 PM
Bob L. The washer spray isn't powered by a pump. Ther... May 12 2014, 06:12 PM
mobymutt
The washer spray isn't powered by a pump. The... May 12 2014, 06:18 PM
Bob L.
The washer spray isn't powered by a pump. Th... May 12 2014, 06:23 PM
mobymutt So I have the wiper switch out now. It does seem ... May 13 2014, 07:16 AM
mobymutt Anybody? I can't seem to get continuity acros... May 13 2014, 05:25 PM
bdstone914 Do you have a wiring diagram? You will need one to... May 13 2014, 10:18 PM
mobymutt I have the wiring 'flow' diagram from the ... May 14 2014, 06:35 AM
eitnurg
I have the wiring 'flow' diagram from the... May 14 2014, 07:04 AM
ripper911 I used the testing procedure in tech tips 700 to d... May 18 2014, 07:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2026 - 10:19 AM |
